Viper 211HV Dome Light Connection
kramttocs
Member - Posts: 24
Posted: January 24, 2020 at 8:27 PM / IP Logged Link to Post Post Reply Quote kramttocs
Regarding dome lights.
The manual has the following:
H1/4 Black/White (from Primary Harness Wire Connection Guide)
"Connect this wire directly to the domelight circuit in the vehicle. The on-board relay will drive circuits up to 30 amps. The polarity of this output is determined by the connection of the input wire H1/3 in the Relay Harness"
So no external relay needed but then in the features section it has:
IGNITION CONTROLLED DOMELIGHT
"If turned on [the feature], the system will turn on the domelight for 30 seconds when the ignition is turned off. The domelight supervision output H1/4 wire must be connected to an optional relay as described in the Primary Harness Wire Connection Guide."
Why does it need an optional relay if it has the on-board one?
In searching this forum I found mention that if it has two wires for the dome light then it has the onboard relay and the 211HV does (1/3 and 1/4) but don't want to risk frying anything should would appreciate some clarification on why the 'feature' says to use a relay.
Ween
Platinum - Posts: 1,368
Posted: January 24, 2020 at 8:49 PM / IP Logged Link to Post Post Reply Quote Ween
The H1/3 and H1/4 wires are the same as contacts 30 and 87 on a relay. I'm guessing a previous 211 model didn't have a relay. DEI used an old manual didn't proofread.
On page 4 of the manual that I have shows primary harness H1 having 12 positions. The description below shows 18 positions.
kramttocs
Member - Posts: 24
Posted: January 24, 2020 at 8:57 PM / IP Logged Link to Post Post Reply Quote kramttocs
Perfect. Thank you.
My favorite part of the manual is the factory disarm wire:
H1/13 LT. GREEN/BLACK Factory Alarm Disarm
This wire supplies a
The suspense is killing me Viper 211HV Dome Light Connection - Last Post -- posted image.
catback
Silver - Posts: 703
Posted: January 25, 2020 at 7:43 AM / IP Logged Link to Post Post Reply Quote catback
You'll have to read Directed's next manual (or at least the manual that section was copy and pasted from) to find out.
