Starter Kill, 1999 Honda Accord
benzo33
Copper - Posts: 87
Posted: April 16, 2020 at 9:52 PM / IP Logged Link to Post Post Reply Quote benzo33
Hello. I was wanting to install a starter interrupt for a 1999 Honda Accord. I wanted clarification on where to install it. Between the key switch and fuse box, or the fuse box and starter? So that I don’t a CEL.
2001 Corolla S and 2005 Neon SRT 4 ACR.
catback
Silver - Posts: 703
Posted: April 17, 2020 at 3:17 PM / IP Logged Link to Post Post Reply Quote catback
Between the key and starter is where most people put it.
Platinum - Posts: 13,725
Posted: April 17, 2020 at 6:36 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Note: If doing starter kill, must interrupt the wire between the starter and the fusebox, not between the fusebox and the ignition switch, to keep the check engine light from coming on.
benzo33
Copper - Posts: 87
Posted: April 28, 2020 at 9:00 AM / IP Logged Link to Post Post Reply Quote benzo33
I connected the fortin Honda sl3 bypass and programmed it. It is connected to the autopage rs 665 via idatalink. It only cranks but does not start. The tach is hardwired. It starts normally with the key. Please advise.
Platinum - Posts: 7,827
Posted: April 28, 2020 at 9:40 AM / IP Logged Link to Post Post Reply Quote kreg357
Not sure if Autopage can go D2D with Fortin bypass modules. Think I would go W2W. It's only a few wires to connect between the R/S and the bypass module and it always works.
Saturday, December 20, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
