2019-2020 Hyundai Santa Fe Wiring
alex_leb
Posted: May 19, 2020 at 11:20 PM / IP Logged Link to Post Post Reply Quote alex_leb
Looking for a wiring diagram for a 2019-2020 hyundai santa fe. door unlock and factory alarm disarm. wires color and location please. Any help would be appreciated.
Alex
tonanzith
Gold - Posts: 603
Posted: October 01, 2020 at 1:35 PM / IP Logged Link to Post Post Reply Quote tonanzith
here you go
2020 Hyundai Santa Fe - North America
Item     Wire Color     Polarity     Wire Location
12 Volts     Blue/Orange and White (15A)     +     Ignition Switch, black 6 pin plug, pins 1 and 5
Second 12 Volts     Red (50A)     +     ICU Junction Block-Dash Fuse Box, white 4 pin plug (B), pin 4
Ground     (chassis ground)
Starter     Black (with IMMO); Pink (w/o IMMO)     +     Ignition Switch, black 6 pin plug, pin 3
Ignition     Green     +     Ignition Switch, black 6 pin plug, pin 4
Accessory     Blue     +     Ignition Switch, black 6 pin plug, pin 2
Second Accessory     Pink     +     Ignition Switch, black 6 pin plug, pin 6
Ignition Interrupt     Gray/Orange     Cut     ICU Junction Block-Dash Fuse Box, rear, white 47 pin plug (G), pin 1
Note - Ignition Interrupt: Only required to retain OEM remote functionality during remote start runtime.
Accessory Interrupt     Pink     Cut     ICU Junction Block-Dash Fuse Box, rear, white 47 pin plug (G), pin 45
Note - Accessory Interrupt: Only required to retain OEM remote functionality during remote start runtime.
Keysense     Green     -     Key Switch, white 6 pin plug, pin 4
CAN Bus High     White (P-CAN)     Data     ICU Junction Block-Dash Fuse Box, rear, black 32 pin plug (F), pin 22
Note - CAN Bus High: Also found in the Driver Kick, white 74 pin plug (MF11), pin 19.
CAN Bus Low     Gray (P-CAN)     Data     ICU Junction Block-Dash Fuse Box, rear, black 32 pin plug (F), pin 23
Note - CAN Bus Low: Also found in the Driver Kick, white 74 pin plug (MF11), pin 20.
CAN Bus High 2     Red (B-CAN)     Data     ICU Junction Block-Dash Fuse Box, rear, black 32 pin plug (F), pin 32
Note - CAN Bus High 2: Also found in the Driver Kick, white 74 pin plug (MF11), pin 63.
CAN Bus Low 2     Blue (B-CAN)     Data     ICU Junction Block-Dash Fuse Box, rear, black 32 pin plug (F), pin 31
Note - CAN Bus Low 2: Also found in the Driver Kick, white 74 pin plug (MF11), pin 62.
CAN Bus High 3     White (D-CAN)     Data     OBD-Data Link Connector, black 16 pin plug, pin 6
CAN Bus Low 3     Brown (D-CAN)     Data     OBD-Data Link Connector, black 16 pin plug, pin 14
OBD 12 Volts     Green (20A)     +     OBD-Data Link Connector, black 16 pin plug, pin 16
OBD Ground     Black     -     OBD-Data Link Connector, black 16 pin plug, pin 4
OBD Ignition     Pink     +     OBD-Data Link Connector, black 16 pin plug, pin 3
OBD Connector     Black          Under Driver Dash, Below Fuse Panel Cover
IMMO Data     White/Orange or Black     Data     Driver Kick, red 54 pin plug (EM11), pin 40
Security Light     (P-CAN)
Power Lock     White/Black (passenger switch)     -     ICU Junction Block-Dash Fuse Box, red 40 pin plug (D), pin 35
Power Unlock     Blue/Orange (passenger switch)     -     ICU Junction Block-Dash Fuse Box, red 40 pin plug (D), pin 27
Lock Motor     Orange     Reverse     ICU Junction Block-Dash Fuse Box, blue 58 pin plug (C), pin 20
Driver Unlock Motor     Blue     Reverse     ICU Junction Block-Dash Fuse Box, blue 58 pin plug (C), pin 30
Passenger Unlock Motor     Red     Reverse     ICU Junction Block-Dash Fuse Box, blue 58 pin plug (C), pin 58
Factory Alarm Arm     (factory remote only)
Factory Alarm Disarm     (transponder and ignition)
Parking Lights     White/Black (LF); Brown (RF)     +     ICU Junction Block-Dash Fuse Box, white 47 pin plug (A), pin 7 (LF); pin 6 (RF)
Parking Lights 2     Green/Black (LR); Yellow/Black (RR)     +     ICU Junction Block-Dash Fuse Box, blue 58 pin plug (C), pin 33 (LR); pin 43 (RR)
Parking Lights -     Yellow     - 1680 Ohms     Headlight-Wiper Switch, black 16 pin plug, pin 14
Parking Lights MUX     Yellow     MUX     Headlight-Wiper Switch, black 16 pin plug, pin 14
Hazards     Pink     -     ICU Junction Block-Dash Fuse Box, rear, black 32 pin plug (F), pin 7
Turn Signal (Left)     Red (LF); Gray (LR)     +     ICU Junction Block-Dash Fuse Box, white 47 pin plug (A), pin 39 (LF); blue 58 pin plug (C), pin 28 (LR)
Turn Signal (Right)     White or Red (RF); White/Black (RR)     +     ICU Junction Block-Dash Fuse Box, white 47 pin plug (A), pin 38 (RF); blue 58 pin plug (C), pin 37 (RR)
Headlight     Blue/Orange     -     Headlight-Wiper Switch, black 16 pin plug, pin 15
AutoLights     Yellow     Cut     Headlight-Wiper Switch, black 16 pin plug, pin 14
Reverse Light     Red/Black     +     ICU Junction Block-Dash Fuse Box, blue 58 pin plug (C), pin 6
Left Front Door Trigger     Gray/Black     -     ICU Junction Block-Dash Fuse Box, red 40 pin plug (D), pin 31
Right Front Door Trigger     Yellow/Black     -     ICU Junction Block-Dash Fuse Box, red 40 pin plug (D), pin 32
Left Rear Door Trigger     White/Black     -     ICU Junction Block-Dash Fuse Box, red 40 pin plug (D), pin 20
Right Rear Door Trigger     Brown/Black     -     ICU Junction Block-Dash Fuse Box, red 40 pin plug (D), pin 19
Dome Light     Brown     -     ICU Junction Block-Dash Fuse Box, rear, black 32 pin plug (F), pin 21
Trunk/Hatch Pin     Brown     -     ICU Junction Block-Dash Fuse Box, red 40 pin plug (D), pin 14
Hood Pin     Pink     -     ICU Junction Block-Dash Fuse Box, white 47 pin plug (A), pin 46
Power Liftgate     Green     -     Power Liftgate Switch, black 16 pin plug, pin 5 --or-- Driver Kick, white 74 pin plug (MF11), pin 30
Trunk/Hatch Release     Gray/Black (rear handle switch)     -     ICU Junction Block-Dash Fuse Box, red 40 pin plug (D), pin 28
Trunk Release Motor     Blue     +     ICU Junction Block-Dash Fuse Box, blue 58 pin plug (C), pin 32
Fuel Door Release     (locks/unlocks along with driver door)
Tachometer     Brown (2.0L-T); Brown/Orange (2.4L)     AC     Camshaft Position Sensor, engine driver side front, gray 3 pin plug, pin 3
Fuel Pump     Red     +     Driver Kick, blue 31 pin plug (EF11), pin 1
Rear Defroster     Green/Orange     - Latched     ICU Junction Block-Dash Fuse Box, white 47 pin plug (A), pin 21
Mirror Defroster     (same as rear defroster)
Left Front Heated Seat     Brown     -     Seat Heater Switch, white 24 pin plug, pin 2
Right Front Heated Seat     Gray     -     Seat Heater Switch, white 24 pin plug, pin 14
Heated Steering Wheel     Green     -     Steering Wheel Heater Switch, white 24 pin plug, pin 9
Speed Sense     Brown     AC     Radio, white 35 pin plug, pin 18 (w/o navigation); white 38 pin plug, pin 38 (with navigation)
Brake Wire     Green/Black     +     Brake Switch, black 6 pin plug, pin 5 --or-- Driver Kick, red 54 pin plug (EM11), pin 48
Parking Brake     Gray/Orange (w/o electric parking brake)     -     ICU Junction Block-Dash Fuse Box, white 47 pin plug (A), pin 44
Horn Trigger     White/Black     -     Horn Switch-Clock Spring, white 14 pin plug, pin 8 --or-- Driver Kick, red 54 pin plug (EM11), pin 4
Horn - Factory Alarm     White     -     ICU Junction Block-Dash Fuse Box, white 47 pin plug (A), pin 10
Wipers     Orange/Black     +     Driver Kick, red 54 pin plug (EM11), pin 24
Left Front Window (Up/Down)     (motor is part of module)
Right Front Window (Up/Down)     Green - Blue (w/o auto); (with auto, motor is part of module)     A     Passenger Power Window Switch, white 12 pin plug, pins 5 - 3
Left Rear Window (Up/Down)     Pink - Brown     A     Left Rear Power Window Switch, white 12 pin plug, pins 5 - 3
Right Rear Window (Up/Down)     Pink - Brown     A     Right Rear Power Window Switch, white 12 pin plug, pins 5 - 3
Sun Roof (Open/Close)     Black - Yellow/Orange (function with ignition on only)     -     Driver Kick, white 74 pin plug (MF11), pins 18 - 7
Memory Seat 1     Red     - Resistor     Driver Memory Switch, black 6 pin plug, pin 3
Memory Seat 2     (same as memory seat 1)     - Resistor
Radio 12V     Red     +     Radio, white 35 pin plug, pin 10
Radio Ground     Black     -     Radio, white 35 pin plug, pin 13
Radio Ignition     White (w/o Idle Stop/Go); Pink (with Idle Stop/Go)     +     Radio, white 35 pin plug, pin 22
Radio Illumination     Red (parking lights); Blue (dimmer)     +,-     Radio, white 35 pin plug, pin 6 (parking lights); pin 19 (dimmer)
Factory Amp Turn-on     (M-CAN)
Power Antenna     Gray/Black     +     Radio, white 35 pin plug, pin 5
Left Front Speaker (+/-)     Brown - White     +,-     Radio, white 38 pin plug, pins 13 - 14
Right Front Speaker (+/-)     Red - Blue     +,-     Radio, white 38 pin plug, pins 16 - 15
Left Rear Speaker (+/-)     Yellow - Black     +,-     Radio, white 38 pin plug, pins 1 - 2
Right Rear Speaker (+/-)     Green - Orange     +,-     Radio, white 38 pin plug, pins 28 - 27
Left Front Speaker - With Amp     Brown - White     +,-     Amplifier under passenger seat, black 28 pin plug, pins 4 - 19
Right Front Speaker - With Amp     Red - Blue     +,-     Amplifier under passenger seat, black 28 pin plug, pins 3 - 18
Left Front Tweeter - With Amp     Black - White     +,-     Amplifier under passenger seat, white 28 pin plug, pins 13 - 26
Right Front Tweeter - With Amp     Orange - Blue     +,-     Amplifier under passenger seat, white 28 pin plug, pins 12 - 25
Left Rear Speaker - With Amp     Yellow - Black     +,-     Amplifier under passenger seat, black 28 pin plug, pins 13 - 26
Right Rear Speaker - With Amp     Green - Orange     +,-     Amplifier under passenger seat, black 28 pin plug, pins 12 - 25
Left Rear Surround - With Amp     White - Brown     +,-     Amplifier under passenger seat, black 28 pin plug, pins 15 - 28
Right Rear Surround - With Amp     Green - Pink     +,-     Amplifier under passenger seat, black 28 pin plug, pins 14 - 27
Center Channel - With Amp     Pink - Yellow     +,-     Amplifier under passenger seat, white 28 pin plug, pins 14 - 27
Subwoofer - With Amp     Green - Orange (coil 1); Blue - Red (coil 2)     +,-     Amplifier under passenger seat, black 28 pin plug, pins 2 - 17 (coil 1); pins 1 - 16 (coil 2)
Aux. Audio Input Left (+/-)     Green - Black/Orange (w/o navigation); Red - Black/Orange (with navigation)     +,-     Radio, white 38 pin plug, pins 24 - 25
Aux. Audio Input Right (+/-)     White - Black/Orange (w/o navigation); Black - Black/Orange (with navigation)     +,-     Radio, white 38 pin plug, pins 10 - 25
Rearview Camera Video     Red - Black     +,-     Radio, white 38 pin plug, pins 7 - 21
Gary Sather
