2011 Nissan Titan, Radio Color Code
jared41
Posted: July 19, 2020 at 2:21 AM / IP Logged Link to Post Post Reply Quote jared41
I need the color code so I can put a radio back in.
Jared Bresux
tonanzith
Gold - Posts: 603
Posted: October 01, 2020 at 1:31 PM / IP Logged Link to Post Post Reply Quote tonanzith
here you go
2011 Nissan Titan - North America
Item     Wire Color     Polarity     Wire Location
Radio 12V     yellow     +     radio, white 20 pin plug, pin 19 or white 10 pin plug, pin 6
Radio Ground     (chassis)
Radio Ignition     violet     +     radio, white 20 pin plug, pin 7 or white 10 pin plug, pin 10
Radio Illumination     red/blue (parking lights); brown (dimmer)     +,-     radio, white 20 pin plug, pins 9, 8 or white 10 pin plug, pins 8, 7
Factory Amp Turn-on     green/white     +     radio, white 6 pin plug, pin 2
Left Front Speaker (+/-)     blue/white - blue/red or white - black     +,-     radio, white 20 pin plug, pins 2 - 3 or white 10 pin plug, pins 2 - 1
Note - Left Front Speaker (+/-): On models with amplifier, the speaker wires are blue/white - blue/red at the amplifier right of steering column, white 24 pin plug, pins 11 - 23. The tweeter wires are blue/white - blue/red at the amplifier, white 24 pin plug, pins 10 - 22.
Right Front Speaker (+/-)     white/black - blue/black or yellow - brown     +,-     radio, white 20 pin plug, pins 11 - 12 or white 10 pin plug, pins 4 - 3
Note - Right Front Speaker (+/-): On models with amplifier, the speaker wires are white/black - blue/black at the amplifier right of steering column, white 24 pin plug, pins 12 - 24. The tweeter wires are white/black - blue/black at the amplifier, white 24 pin plug, pins 9 - 21.
Left Rear Speaker (+/-)     lt. blue - black/yellow or brown - black/red     +,-     radio, white 20 pin plug, pins 4 - 5 or white 6 pin plug, pins 4 - 3
Note - Left Rear Speaker (+/-): On models with amplifier, the speaker and tweeter wires are lt. blue - black/yellow at the amplifier right of steering column, white 24 pin plug, pins 7 - 19.
Right Rear Speaker (+/-)     orange/blue - red/blue or blue - black/white     +,-     radio, white 20 pin plug, pins 13 - 14 or white 6 pin plug, pins 6 - 5
Note - Right Rear Speaker (+/-): On models with amplifier, the speaker and tweeter wires are orange/blue - red/blue at the amplifier right of steering column, white 24 pin plug, pins 8 - 20.
Center Channel (+/-)     blue/white - blue/black     +,-     amplifier right of steering column, white 24 pin plug, pins 6 - 18
Subwoofer (+/-)     white - black (1); brown/white - brown (2)     +,-     amplifier right of steering column, white 8 pin plug, pins 2 - 6; 3 - 7
Aux. Audio Input Left (+/-)     red - black     +,-     radio, white 16 pin plug, pins 15 - 16
Aux. Audio Input Right (+/-)     white - black     +,-     radio, white 16 pin plug, pins 14 - 16
RSE Video (+/-)     black/white - blue     +,-     DVD player in ctr console, bu 16 pin plg, pins 7-8
RSE Audio Left (+/-)     black - white     +,-     radio, white 20 pin plug, pins 15 - 14
RSE Audio Right (+/-)     red - green     +,-     radio, white 20 pin plug, pins 17 - 16
Satellite Radio 12 Volts     yellow     +     Sat Radio R of strng column, wh 16 pin plg, pin 12
Satellite Radio Ground     (chassis)
Satellite Radio Ignition     violet     +     Sat Radio R of strng column, wh 16 pin plg, pin 16
Satellite Radio Antenna     (coaxial cable)
Satellite Audio Left (+/-)     red - green     +,-     Satellite Radio, white 16 pin plug, pins 2 - 1
Satellite Audio Right (+/-)     white - black     +,-     Satellite Radio, white 16 pin plug, pins 4 - 3
Gary Sather
