Wireless Bus Door Opener
rolandbremb
Posted: July 30, 2020 at 12:36 PM / IP Logged Link to Post Post Reply Quote rolandbremb
Hello!
I'm currently converting my van to a camper. The van was used as a passenger bus before, and has a passenger door in the back the flips open by activating a switch on the console. My plan is to install a wireless switch relay to be able to open the door from the outside with a fob. I found THIS or THIS that I think would get the job done.
The problem is now that I don't know anything about the wires going from the door motor to the actual switch. All I can tell is that there are 2 red wires, 1 blue wire and then some brown or black ones going into the switch. Any ideas on how I can make that work?
Thanks, Roland
Wireless Bus Door Opener - Last Post -- posted image.Wireless Bus Door Opener - Last Post -- posted image.Wireless Bus Door Opener - Last Post -- posted image.
Platinum - Posts: 7,828
Posted: July 31, 2020 at 1:41 PM / IP Logged Link to Post Post Reply Quote kreg357
Do you have a Digital Multi Meter? Can you pop out that switch panel and take a picture of the wires going to that switch?
Controlling the door by making your connection(s) at the switch might be the easiest way to accomplish your goal. As far as the remote control system, does the van currently have remote keyless entry? You might be able to use a more common auto RKE system that would do more than just the side door.
