2017 Hyundai Tucson, Standard Key, Remote Start Wiring
jaredtr1999
Posted: September 27, 2020 at 11:56 AM / IP Logged Link to Post Post Reply Quote jaredtr1999
Hello! I’m in need of a remote start/ full wiring diagram for a 2017 Hyundai Tucson with the standard key (hopefully with the location of the lock/unlock wires in the dash.
Thanks in advance!
tonanzith
Gold - Posts: 603
Posted: October 01, 2020 at 1:07 PM / IP Logged Link to Post Post Reply Quote tonanzith
here you go:
2017 Hyundai Tucson - North America
Item     Wire Color     Polarity     Wire Location
12 Volts     Gray (30A)     +     Ignition Switch, black 6 pin plug, pin 1
Second 12 Volts     Green (40A)     +     Ignition Switch, black 6 pin plug, pin 5
Ground     (chassis ground)
Starter     Red     +     Ignition Switch, black 6 pin plug, pin 3
Ignition     Blue     +     Ignition Switch, black 6 pin plug, pin 4
Accessory     Green     +     Ignition Switch, black 6 pin plug, pin 2
Second Accessory     White     +     Ignition Switch, black 6 pin plug, pin 6
Keysense     Pink     -     Key Switch, white 6 pin plug, pin 4
CAN Bus High     Green (C-CAN)     Data     OBD-Data Link Connector, black 16 pin plug, pin 6
CAN Bus Low     Orange (C-CAN)     Data     OBD-Data Link Connector, black 16 pin plug, pin 14
CAN Bus High 2     Green/Black (B-CAN)     Data     Dash Fuse Box, rear, white 18 pin plug (F), pin 3
CAN Bus Low 2     Blue/Black (B-CAN)     Data     Dash Fuse Box, rear, white 18 pin plug (F), pin 4
IMMO Data     Blue/Black (EMS COM)     Data     Driver Kick, blue 48 pin plug, pin 3
K Line     White     Data     OBD-Data Link Connector, black 16 pin plug, pin 12
Power Lock     Blue/Black     -     Dash Fuse Box, white 32 pin plug (D), pin 27
Power Unlock     Gray/Black     -     Dash Fuse Box, white 32 pin plug (D), pin 14
Lock Motor     Orange     Reverse     Dash Fuse Box, black 51 pin plug (C), pin 8
Driver Unlock Motor     Pink     Reverse     Driver Kick, white 68 pin plug, pin 64
Passenger Unlock Motor     Pink     Reverse     Dash Fuse Box, black 51 pin plug (C), pin 26
Factory Alarm Arm     Red (see Tech Doc 1300)     -     Dash Fuse Box, white 32 pin plug (D), pin 13
Factory Alarm Disarm     Pink (see Tech Doc 1300)     Double -     Dash Fuse Box, white 32 pin plug (D), pin 12
Lock Detection     Gray (see Tech Doc 1300)     Open     Dash Fuse Box, white 32 pin plug (D), pin 9
Unlock Detection     (same as lock detection)     -
Parking Lights     Blue/Orange (LF); Green (RF); Pink (LR); Yellow (RR)     +     Dash Fuse Box, white 41 pin plug (A), pins 12, 29; black 51 pin plug (C), pins 50, 19
Parking Lights -     Yellow     - 1680 Ohms     Headlight-Wiper Switch, black 16 pin plug, pin 14
Parking Lights MUX     Yellow     MUX     Headlight-Wiper Switch, black 16 pin plug, pin 14
Hazards     Yellow     -     Dash Fuse Box, rear, gray 51 pin plug (E), pin 30
Turn Signal (Left)     Yellow (F); White (R)     +     Dash Fuse Box, white 41 pin plug (A), pin 3; black 51 pin plug (C), pin 10
Turn Signal (Right)     White/Black (F); Pink (R)     +     Dash Fuse Box, white 41 pin plug (A), pin 39; black 51 pin plug (C), pin 39
Headlight     Yellow     - 5580 Ohms     Headlight-Wiper Switch, black 16 pin plug, pin 14
AutoLights     Yellow     Cut     Headlight-Wiper Switch, black 16 pin plug, pin 14
Reverse Light     Red     +     Dash Fuse Box, black 51 pin plug (C), pin 11
Left Front Door Trigger     Blue     -     Dash Fuse Box, white 32 pin plug (D), pin 23
Right Front Door Trigger     Pink     -     Dash Fuse Box, white 32 pin plug (D), pin 8
Left Rear Door Trigger     Brown     -     Dash Fuse Box, white 32 pin plug (D), pin 22
Right Rear Door Trigger     Gray     -     Dash Fuse Box, white 32 pin plug (D), pin 21
Dome Light     Brown/Orange     -     Left Front Pillar, white 36 pin plug, pin 8
Trunk/Hatch Pin     White     -     Dash Fuse Box, white 32 pin plug (D), pin 25
Hood Pin     Orange/Black     -     Dash Fuse Box, white 41 pin plug (A), pin 38
Power Liftgate     Green/Black     -     Power Liftgate Switch, black 16 pin plug, pin 5
Trunk/Hatch Release     Green (rear handle switch)     -     Dash Fuse Box, white 32 pin plug (D), pin 24
Trunk Release Motor     Blue     +     Dash Fuse Box, black 51 pin plug (C), pin 51
Tachometer     Black/Orange (1.6L); Red (2.0L)     ac     Camshaft Position Sensor on engine driver side, black 3 pin plug, pin 2
Fuel Pump     White     +     Right of Dash Fuse Box, white 24 pin plug, pin 12
Rear Defroster     Green/Orange     - Latched     Dash Fuse Box, white 41 pin plug (A), pin 17
Mirror Defroster     (same as rear defroster)
Wiper Deicer     (same as rear defroster)
Left Front Heated Seat     Blue     +     A/C Control, white 24 pin plug, pin 2 or white 32 pin plug, pin 5
Right Front Heated Seat     Red     +     A/C Control, white 24 pin plug, pin 14 or white 32 pin plug, pin 17
Speed Sense     Brown     ac     Radio, white 24 pin plug, pin 16 or white 38 pin plug, pin 38
Brake Wire     Green/Black     +     Brake Switch or Dash Fuse Box, white 41 pin plug (A), pin 37
Parking Brake     Gray/Orange     -     Dash Fuse Box, white 41 pin plug (A), pin 8
Horn Trigger     Gray/Orange     -     Horn Switch or Driver Kick, blue 48 pin plug, pin 42
Wipers     Blue     +     Driver Kick, blue 48 pin plug, pin 21
Left Front Window (Up/Down)     White - Pink (without auto up); (motor is part of module, with auto up)     A     Power Window Main Switch, white 18 pin plug, pins 8 - 9
Right Front Window (Up/Down)     Gray - Green     A     Driver Kick, door harness
Left Rear Window (Up/Down)     Pink - Brown     A     Driver Kick, door harness
Right Rear Window (Up/Down)     Blue - Orange     A     Driver Kick, door harness
Sun Roof (Open/Close)     Brown and Green (open) (functions with ignition on only)     Both -     Sunroof Switch, white 6 pin plug, pins 5, 6
Sun Roof (Limit/Close)     Yellow and Green (close) (functions with ignition on only)     Both -     Sunroof Switch, white 6 pin plug, pins 3, 2
Radio 12V     Red     +     Radio, white 24 pin plug, pin 12 or white 35 pin plug, pin 10
Radio Ground     Black     -     Radio, white 24 pin plug, pin 24 or white 35 pin plug, pin 12
Radio Ignition     Blue/Orange     +     Radio, white 24 pin plug, pin 11 or 18 or white 35 pin plug, pin 22
Radio Illumination     Red/Orange (parking lights); Blue/Orange (dimmer)     +,-     Radio, white 18 pin plug, pins 8, 17 or white 35 pin plug, pins 6, 19
Factory Amp Turn-on     (M-CAN)
Power Antenna     Green     +     Radio, white 18 pin plug, pin 18 or white 35 pin plug, pin 5
Left Front Speaker (+/-)     White - Brown     +,-     Radio, white 18 pin plug, pins 2 - 11 or white 38 pin plug, pins 13 - 14
Note - Left Front Speaker (+/-): On models with amplifier, the speaker wires are white - brown (woofer); red - brown (tweeter) at the amplifier on right rear cargo floor, black 28 pin plug, pins 26 - 25; 3 - 4 (without JBL); black 28 pin plug, pins 4 - 19 (with JBL).
Right Front Speaker (+/-)     Black - Yellow or Red - Blue     +,-     Radio, white 18 pin plug, pins 3 - 12 or white 38 pin plug, pins 16 - 15
Note - Right Front Speaker (+/-): On models with amplifier, the speaker wires are red - blue (woofer); brown - blue (tweeter) at the amplifier on right rear cargo floor, black 28 pin plug, pins 28 - 27; 1 - 2 (without JBL); black 28 pin plug, pins 1 - 2 (with JBL).
Left Rear Speaker (+/-)     Black - Yellow or Red - Blue     +,-     Radio, white 18 pin plug, pins 1 - 10 or white 38 pin plug, pins 1 - 2
Note - Left Rear Speaker (+/-): On models with amplifier, the speaker wires are black - yellow at the amplifier on right rear cargo floor, black 28 pin plug, pins 15 - 14 or 13 - 26.
Right Rear Speaker (+/-)     Green - Orange     +,-     Radio, white 18 pin plug, pins 4 - 13 or white 38 pin plug, pins 28 - 27
Note - Right Rear Speaker (+/-): On models with amplifier, the speaker wires are green - orange at the amplifier on right rear cargo floor, black 28 pin plug, pins 13 - 12 or 12 - 25.
Center Channel (+/-)     Red - Blue     +,-     Amplifier on right rear cargo floor, white 28 pin plug, pins 28 - 27 or black 28 pin plug, pins 14 - 27
Subwoofer (+/-)     Green - Orange (1); Blue - Red (2)     +,-     Amplifier on right rear cargo floor, black 28 pin plug, pins 16 - 17; 18 - 19 or 2 - 17; 1 - 16
Aux. Audio Input Left (+/-)     White or Red - Black/Orange     +,-     Radio, white 24 pin plug, pins 21 - 9 or white 38 pin plug, pins 24 - 25
Aux. Audio Input Right (+/-)     Black - Black/Orange     +,-     Radio, white 24 pin plug, pins 8 - 9 or white 38 pin plug, pins 10 - 25
Rearview Camera Video     Yellow - Brown     +,-     Radio, white 16 pin plug, pins 4 - 3 or white 38 pin plug, pins 7 - 21 or white 24 pin plug, pins 23 - 22
Gary Sather
Monday, February 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
