2001 Ford F-150, Remote Start, Crank No Start
louwap22
Posted: January 07, 2021 at 12:20 PM / IP Logged Link to Post Post Reply Quote louwap22
Hello All, Im a newb so please delete if I broke rules. Ive done research and Kreg's post on this vehicle did help a lot. So big shout out to him. I have a my push cart remote start I am install for my bosses son. I have a crank and no start issue. on the module 12pin side. I have an orange with black wire that goes to the trucks dk grn and violet wire. I cannot find this. I also researched this and apparently it is a myth. I have the main ignition set, also the lock and unlock portion as well. Is there something I am missing or does this need to get flashed? Thanks in advance and sorry if I screwed up.
Lou
***UPDATE***
Had to reprogram with an option, Got it to start! However, I cannot get the remote to work to unlock or lock doors... Thanks again
Smartech
Platinum - Posts: 7,828
Posted: January 07, 2021 at 3:49 PM / IP Logged Link to Post Post Reply Quote kreg357
The PushCart system is a Crimestopper RS3 Remote Start & Keyless Entry?
Are the locks Type C or Type B in your truck?
Where did you make the lock wire connections?
