2010 Scion tC, Stereo Wiring
kristen obregon
Posted: May 15, 2021 at 3:06 PM / IP Logged Link to Post Post Reply Quote kristen obregon
I have a scion tc with a factory pioneer radion and im trying to install my system to my factory head unit but i have no clue what wires go where cause im using the box thats used so u can keep your factory radio... pkease help.
kristen obregon
It is nma automatic and not a push to start.
Platinum - Posts: 13,725
Posted: May 15, 2021 at 7:07 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Radio Ignition      gray      +      radio, white 10 pin plug, pin 3
Radio Illumination      green (parking lights); white (dimmer)      +,-      radio, white 10 pin plug, pin 10; white 6 pin plug, pin 5
Factory Amp Turn-on      white (subwoofer amp)      +      radio, white 10 pin plug, pin 9
Power Antenna      orange      +      radio, white 10 pin plug, pin 8
Left Front Speaker (+/-)      pink - violet      +,-      radio, white 10 pin plug, pins 2 - 6
Right Front Speaker (+/-)      lt. green - blue      +,-      radio, white 10 pin plug, pins 1 - 5
Left Rear Speaker (+/-)      brown - yellow      +,-      radio, white 6 pin plug, pins 2 - 6
Right Rear Speaker (+/-)      red - white      +,-      radio, white 6 pin plug, pins 1 - 3
Subwoofer (+/-)      (paralleled with front speakers)
Aux. Audio Input Left (+/-)      black - yellow      +,-      radio, white 20 pin plug, pins 17 - 16
Aux. Audio Input Right (+/-)      blue - yellow      +,-      radio, white 20 pin plug, pins 15 - 16
kristen obregon
Posted: May 15, 2021 at 10:19 PM / IP Logged Link to Post Post Reply Quote kristen obregon
Thank u so much.. heres snother question which wire do i connect my remote wire to from my aftermarket amp??
Posted: May 16, 2021 at 7:57 PM / IP Logged Link to Post Post Reply Quote i am an idiot
If it does not have a factory subwoofer,
this wire will turn the amp on anytime the key is in the on or acc position.
If it does have a factory sub use
Monday, February 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
