2013 Fiat Abarth 5-Speed, Remote Start, Alarm Wiring
caraudioholic24
Member - Posts: 37
Posted: July 22, 2021 at 11:18 AM / IP Logged Link to Post Post Reply Quote caraudioholic24
Good day, I recently acquired a new to me 2013 Fiat Abarth (5 Speed) I want to install a Full remote start, Alarm and keyless entry system. I have a "Manual" safe Viper unit but I am having an issue finding a wiring diagram for the vehicle. I prefer directechs if possible but will take anything.. (clutch switch bypass etc.) I have tried idatalink but they only show info for the Basic 500 automatic.. so I have some of the wiring needed.. Any help is appreciated
mgoetz74
Silver - Posts: 424
Posted: July 22, 2021 at 1:17 PM / IP Logged Link to Post Post Reply Quote mgoetz74
this is from directech and is the abarth
12 Volts     red/dk. green (20A)     +     ignition switch, white 3 pin plug, pin 2
Second 12 Volts     red/black (60A)     +     BCM/dash fuse box, black 1 pin plug, pin 1
Ground     (chassis ground)
Starter     brown     +     ignition switch, white 3 pin plug, pin 3
Ignition     dk. blue     +     ignition switch, white 4 pin plug, pin 2
Second Ignition     orange     +     ignition switch, white 3 pin plug, pin 1
Accessory     gray     +     ignition switch, white 4 pin plug, pin 1
Key Release     brown/orange     cut     key lock solenoid, white 2 pin plug, pin 2
CAN Bus High     dk. green (CAN C BUS)     data     data link connector, black 16 pin plug, pin 6
CAN Bus Low     brown (CAN C BUS)     data     data link connector, black 16 pin plug, pin 14
CAN Bus High 2     dk. blue (CAN B BUS)     data     data link connector, black 16 pin plug, pin 1
CAN Bus Low 2     white (CAN B BUS)     data     data link connector, black 16 pin plug, pin 9
Power Lock     violet/red (need to relay isolate, see Tech Doc 1701)     - 470 ohms     driver kick or BCM/dash fuse box, black/blue 60 pin plug, pin 51
Power Unlock     (same as power lock)     -
Lock Motor     white/black     5 wire     driver kick or BCM/dash fuse box, black 32 pin plug, pin 16
Driver Unlock Motor     orange/green     5 wire     driver kick or BCM/dash fuse box, black 32 pin plug, pin 31
Factory Alarm Arm     (factory remote only)
Factory Alarm Disarm     (factory remote only)
Parking Lights     yellow/red (LF); yellow/black (RF); yellow/red (LR); yellow/black (RR)     +     BCM/dash fuse box, black/blue 60 pin plug, pins 29, 15; purple/blue 60 pin plug, pins 6, 5
Parking Lights -     yellow/black     -     headlight switch, gray 9 pin plug, pin 7
Hazards     dk. green/red     -     hazard switch, black 8 pin plug, pin 1
Turn Signal (Left)     dk. blue/white (F); dk. blue/white (R)     +     BCM/dash fuse box, black/blue 60 pin plug, pin 10; purple/blue 60 pin plug, pin 1
Turn Signal (Right)     dk. blue/black (F); dk. blue/black (R)     +     BCM/dash fuse box, black/blue 60 pin plug, pin 8; purple/blue 60 pin plug, pin 3
Headlight     gray/dk. green (L); gray/black (R)     +     BCM/dash fuse box, black 32 pin plug, pins 10, 27
Reverse Light     gray/dk. green     +     BCM/dash fuse box, purple/blue 60 pin plug, pin 44
Right Front Door Trigger     white/red     -     BCM/dash fuse box, black/blue 60 pin plug, pin 53
Dome Light     gray/dk. blue     -     BCM/dash fuse box, purple/blue 60 pin plug, pin 9
Trunk/Hatch Pin     white/gray     -     BCM/dash fuse box, purple/blue 60 pin plug, pin 39
Trunk/Hatch Release     white/orange (rear handle switch)     -     BCM/dash fuse box, purple/blue 60 pin plug, pin 35
Trunk Release Motor     violet     5 wire     BCM/dash fuse box, black 32 pin plug, pin 30
Fuel Door Release     (locks/unlocks along with driver door)
Tachometer     dk. blue/black, white/gray, brown/black, or black/red     ac     any fuel injector, black 2 pin plug, pin 2
Clutch Pedal     violet/red and brown/black     + and open     clutch switch, black 3 pin plug, pins 2, 3
Fuel Pump     dk. green/orange     +     driver kick, harness to rear
Rear Defroster     brown/dk. blue     - latched     BCM/dash fuse box, black/blue 60 pin plug, pin 6
Mirror Defroster     (same as rear defroster)
Left Front Heated Seat     brown/white     - resistor     heated seat switch, black 6 pin plug, pin 2
Right Front Heated Seat     (same as left front heated seat)     - resistor
Speed Sense     gray/yellow (with sunroof only)     ac     BCM/dash fuse box, purple/blue 60 pin plug, pin 57
Brake Wire     dk. green/white (functions with ignition on only)     +     BCM/dash fuse box, black/blue 60 pin plug, pin 27
Parking Brake     white/yellow     -     BCM/dash fuse box, purple/blue 60 pin plug, pin 19
Horn Trigger     dk. green/white     -     BCM/dash fuse box, black/blue 60 pin plug, pin 1
Wipers     white (LO); white/red (HI)     +     BCM/dash fuse box, black 32 pin plug, pin 3; black/blue 60 pin plug, pin 39
caraudioholic24
Member - Posts: 37
Posted: November 12, 2021 at 4:16 AM / IP Logged Link to Post Post Reply Quote caraudioholic24
Forgot to Thank You for the help! Thanks
