Viper Remote Start Won’t Start Car After Key Reseed
Platinum - Posts: 7,828
Posted: November 27, 2021 at 9:12 PM / IP Logged Link to Post Post Reply Quote kreg357
Here is a link to the current ADS AL-CA w/TL1 firmware guide. http://images.idatalink.com/corporate/Content/Manuals/DL-TL1/DBI-AL(DL)-TL1-EN_20140604.pdf
On Page 13 is the programming steps for a Type 1 install. It looks like everything goes well until Step 8. Not sure how long the wait is but the LED is supposed to go solid Green for 2 seconds and out. This is assuming the Camry has an immobilizer. From your mention that the engine will R/S with a key in the ignition switch but not turned, it sounds like you have an immobilizer and the bypass didn't learn/save that info during programming for use during a R/S.
At this point, I would double check the ADS AL-CA wire connections to the vehicles' RX and RX wires. This is shown on Page 6 for the Type 1 install.
Additionally, they ADS AL-CA programming steps could have changed over the years. I'm not sure how long ago your system was flashed/installed and what Version of Firmware was used. It might be a good idea to check all the wiring on the ADS AL-CA and the Viper (thin wires) to get a better idea of how your install was done.
grego773
Member - Posts: 7
Posted: November 30, 2021 at 4:16 PM / IP Logged Link to Post Post Reply Quote grego773
You are the best! Literally the last time I was going to try too 🙃. As you know there are two program modes. Mode 1 = 1 green flash. Mode 2 = 2 green flash. After reset we press and hold until green lights for 2 secs. That put me in Mode 1. I needed Mode 2. I either pressed the button 2x until flashing grn 2x, than I pressed and held til stayed green for 2 secs OR I pressed and held for 2 secs and than pressed and held for 2 secs again to enter Mode 2. I think I pressed the button 2x first right after reset. Than when the led was blinking 2x for Mode 2, I pressed and held the button for until green lit for 2 secs and stayed off. Than follow rest of the steps. Insert key, turn,remove wait 5 secs and insert without turning. Thank you so much. Happy holidays! The best part is figuring it out.
Wednesday, March 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
