Electronic Fuel Gauge Needle Fluctuation
sky65
Member - Posts: 9
Posted: May 29, 2023 at 10:22 PM / IP Logged Link to Post Post Reply Quote sky65
Not sure if I am in the right section. Please advise if not.
I have a 65 Corvette and I recently installed an analog reading electronic gauge set including a fuel gauge. I am using the stock 0-90 ohm tank sender. The gauge needle fluctuates wildly while driving. I'm pretty sure the cause is the stock sender in a non-baffled tank. The level reading appears close when the car is not moving. I have seen some info to reduce the sensitivity of the gauge by installing a capacitor across the signal and ground wires at the sender but not real details or specs. The gauge supplier has not been helpful with other issues with the gauge set a purchased. Any thoughts on this?
Tom
Platinum - Posts: 13,726
Posted: June 01, 2023 at 8:13 PM / IP Logged Link to Post Post Reply Quote i am an idiot
100 microfarad at least 25 volts. Negative lead of the capacitor to ground. The other lead of the capacitor to the output wire of the sending unit.
sky65
Member - Posts: 9
Posted: June 01, 2023 at 10:27 PM / IP Logged Link to Post Post Reply Quote sky65
Thanks!
Tom
