2007 GMC Yukon Denali, Alarm Wiring?
olj1970
Posted: May 01, 2024 at 4:48 PM / IP Logged Link to Post Post Reply Quote olj1970
Good evening! Im looking to install a alarm my 2007 Yukon Denali but I can't find the wiring for my 2007 Yukon Denali can anyone help me please.
Olj
tonanzith
Gold - Posts: 603
Posted: May 22, 2024 at 5:40 PM / IP Logged Link to Post Post Reply Quote tonanzith
Item      Wire Color      Polarity      Wire Location      Photo      Note
12 Volts      red/white (15A)      +      BCM left of steering column, black 25 pin plug, pin 1      Directwire
Second 12 Volts      red/black (60A)      +      dash fuse box, black 40 pin plug (X1), pin F1      Directwire
Ground      (chassis ground)
Starter Kill      violet      +      starter or underhood fuse box, black 50 pin plug (X2), pin F1 or F5      Directwire
Second Starter      pink/black (R Code) (see Tech Doc 1605)      +9600 ohms      ignition switch, black 6 pin plug, pin 5      Directwire
Ignition      pink      +      ignition switch, black 6 pin plug, pin 2      Directwire
Accessory      brown or yellow      +      ignition switch, black 6 pin plug, pin 3      Directwire      Notes
Second Accessory      (same as second starter)      +6300 ohms
Keysense      (same as second starter)
CAN Bus High      tan/black      data      OBD-data link connector, black 16 pin plug, pin 6      Directwire
CAN Bus Low      tan      data      OBD-data link connector, black 16 pin plug, pin 14      Directwire
CAN Bus SW      dk. green      data      OBD-data link connector, black 16 pin plug, pin 1      Directwire
OBD 12 Volts      red/white (20A)      +      OBD-data link connector, black 16 pin plug, pin 16
OBD Ground      black      -      OBD-data link connector, black 16 pin plug, pin 4
OBD Connector      Black           Under Driver Dash, Above Brake Pedal      Directwire
IMMO Data      dk. green      data      Immobilizer Control Module on ignition switch, black 5 pin plug, pin 4      Directwire
IMMO Power      red/white      +      Immobilizer Control Module on ignition switch, black 5 pin plug, pin 1      Directwire
Power Lock      (use Directed interface module or see Tech Doc 1601)                Directwire      Notes
Power Unlock      (see power lock)
Lock Motor      gray      5 wire      driver kick or dash fuse box, black 14 pin plug (X3), pin B4      Directwire
Driver Unlock Motor      violet      5 wire      driver window switch, brown 16 pin plug, pin 8      Directwire
Passenger Unlock Motor      tan      5 wire      driver kick or dash fuse box, black 14 pin plug (X3), pin B1      Directwire
Factory Alarm Arm      (arms on lock with door open)
Factory Alarm Disarm      lt. green (driver door key unlock)      -      driver window switch, brown 16 pin plug, pin 4      Directwire
Disarm No Unlock      (Passkey and ignition)
Parking Lights      brown (L); brown (R)      +      underhood fuse box, black 30 pin plug (X3), pins A7, F7
Parking Lights -      lt. blue      -      BCM left of steering column, white 25 pin plug, pin 8 or headlight switch      Directwire
Hazards      white      -      hazard switch or BCM left of strng column, lt. green plug, pin 19      Directwire
Turn Signal (Left)      lt. blue/white (F); yellow or yellow/black (R)      +      BCM left of steering column, brown plug, pins 4, 1      Directwire
Turn Signal (Right)      dk. blue/white (F); dk. green or dk. green/wht (R)      +      BCM left of steering column, black plug, pin 5; brown plug, pin 2      Directwire
Headlight      white      -      headlight switch or BCM left of strng column, white plug, pin 12      Directwire
AutoLights      dk. green      - (off)      headlight switch or BCM, white plug, pin 17      Directwire
Reverse Light      dk. blue      +      BCM left of steering column, white plug, pin 22      Directwire
Left Front Door Trigger      gray/black (ajar); tan (open)      -      driver window switch, brown 16 pin plug, pins 13; 11      Directwire
Right Front Door Trigger      black/white or tan/white      -      passenger window switch, brown 16 pin plug, pin 13      Directwire
Left Rear Door Trigger      lt. blue/black      -      BCM left of steering column, pink plug, pin 15      Directwire
Right Rear Door Trigger      lt. green/black      -      BCM left of steering column, pink plug, pin 14      Directwire
Dome Light      gray      +      BCM left of steering column, white plug, pin 5      Directwire
Trunk/Hatch Pin      pink/black      -      BCM left of steering column, pink plug, pin 12      Directwire      Notes
Rear Glass Pin      (same as trunk/hatch pin)                     Notes
Hood Pin      pink/black      -      hood switch or BCM left of strng column, black plug, pin 17      Directwire
Trunk/Hatch Release      gray (liftgate); pink (liftglass) (rear handle sw)      -      BCM left of steering column, pink plug, pins 13, 24      Directwire      Notes
Trunk Release Motor      lt. blue (liftgate)      +      passenger kick, harness to rear      Directwire      Notes
Tachometer      NOT pink      ac      any fuel injector      Directwire
Fuel Pump      dk. green/white      +      ECM, black 73 pin plug (X1), pin 50           Notes
Rear Defroster      violet      reverse      driver kick, harness to rear      Directwire
Mirror Defroster      orange or black (L); orange or black (R)      + latched      driver and passenger window switch, black 10 pin plug, pin 7      Directwire
Left Front Heated Seat      dk. blue (back and cushion)      -      driver window switch, gray 14 pin plug, pin 6      Directwire
Right Front Heated Seat      dk. blue (back and cushion)      -      passenger window switch, gray 14 pin plug, pin 6
Speed Sense      dk. green/white (some models only)      ac      EBCM, blk 38 pin plug, pin 11 or 32 or radio, brn 16 pin plug, pin 5           Notes
Brake Wire      lt. blue/white (functions with ignition on only)      +      brake switch or BCM left of strng column, brown plug, pin 6      Directwire
Parking Brake      lt. blue      -      parking brake switch or BCM left of strng column, brown plug, pin 16      Directwire
Horn Trigger      tan      -      horn switch or BCM left of strng column, brown plug, pin 18      Directwire
Wipers      gray      +      BCM left of steering column, brown plug, pin 20      Directwire
Left Front Window (Up/Down)      dk. blue - brown      A      driver window switch, black 6 pin plug, pins 3 - 1      Directwire      Notes
Right Front Window (Up/Down)      dk. blue - brown      A      passenger window switch, black 6 pin plug, pins 3 - 1      Directwire
Left Rear Window (Up/Down)      dk. blue - brown      A      left rear window switch, black 8 pin plug, pins E - H
Right Rear Window (Up/Down)      dk. blue - brown      A      right rear window switch, black 8 pin plug, pins E - H
Sun Roof (Open/Close)      brown - orange or lt. blue (func with ign on only)      -      sunroof switch, black 8 pin plug, pins 6 - 4      Directwire
Memory Seat 1      orange      +2260 ohms      driver window switch, gray 14 pin plug, pin 5      Directwire
Memory Seat 2      (same as memory seat 1)      +4260 ohms
Radio 12V      red/white      +      radio, black 14 pin plug, pin 1
Radio Ground      black      -      radio, black 14 pin plug, pin 8
Radio Ignition      (low speed GMLAN)
Radio Illumination      yellow (dimmer)      +      radio, black 14 pin plug, pin 7
Factory Amp Turn-on      (same as power antenna) (some models only)
Power Antenna      white      +      radio, black 14 pin plug, pin 6
Left Front Speaker (+/-)      tan - gray or tan - dk. green      +,-      radio, black 14 pin plug, pins 2 - 9           Notes
Right Front Speaker (+/-)      lt. green - dk. green or lt. green/white - org/blk      +,-      radio, black 14 pin plug, pins 3 - 10           Notes
Left Rear Speaker (+/-)      brown - yellow or brown/white - brown      +,-      radio, black 16 pin plug, pins 5 - 13           Notes
Right Rear Speaker (+/-)      dk. blue - lt. blue or dk. blue - tan      +,-      radio, black 16 pin plug, pins 6 - 14           Notes
Center Channel (+/-)      dk. blue - orange (with surround)      +,-      radio, brown 16 pin plug, pins 3 - 11           Notes
Subwoofer (+/-)      white - pink (with surround)      +,-      radio, brown 16 pin plug, pins 4 - 12           Notes
Aux. Audio Input Left (+/-)      yellow - (bare wire)      +,-      radio, gray 16 pin plug, pins 1 - 9      Directwire      Notes
Aux. Audio Input Right (+/-)      white - (bare wire)      +,-      radio, gray 16 pin plug, pins 2 - 9
RSE Video (+/-)      dk. green - white/black      +,-      radio, gray 16 pin plug, pins 7 - 15      Directwire      Notes
RSE Audio Left (+/-)      lt. blue - violet      +,-      radio, gray 16 pin plug, pins 3 - 11
RSE Audio Right (+/-)      white - violet      +,-      radio, gray 16 pin plug, pins 4 - 11
Satellite Radio 12 Volts      red/white      +      Sat Radio behind glove box, blk 16 pin plg, pin 16
Satellite Radio Ground      black      -      Sat Radio behind glove box, blk 16 pin plg, pin 9
Satellite Radio Ignition      (low speed GMLAN)
Satellite Radio Antenna      (coaxial cable)
Satellite Audio Left (+/-)      brown/white - tan/white      +,-      Satellite Radio, black 16 pin plug, pins 2 - 1
Satellite Audio Right (+/-)      dk. green/white - gray      +,-      Satellite Radio, black 16 pin plug, pins 3 - 4
Item      Size      Depth      Location
Headunit      double DIN           center of dash
Left Front Speaker      6.5           left front door
Right Front Speaker      6.5           right front door
Left Rear Speaker      5.25           left rear door
Right Rear Speaker      5.25           right rear door
Gary Sather
