Autostart 2 Way Remote Stopped Working After Car’s Battery Died
albertkao
Member - Posts: 11
Posted: March 16, 2025 at 2:11 PM / IP Logged Link to Post Post Reply Quote albertkao
lee.lopez wrote:
Let's start from the beginning. Look on the inside of your windshield near the top. Do you see the antenna pictured above? If not, you need to find the remote start module. Once you locate it, look for a black flat, multi wire cable. Follow that wire to the antenna pictured above.
Thanks for your help! Would you mind helping further, please?
I located the antenna (see photo at https://photos.app.goo.gl/QENSmQjiBNNduD9P6 ).
The antenna LED is blue.
1. I turn the key to IGN ON but do not start the vehicle.
2. I press, release then press and hold the antenna programming button many times, but the antenna LED do not start flashing rapidly.
3. I press, and hold f or Side button but the remote do not generate a long beep.
lee.lopez
Copper - Posts: 307
Posted: March 16, 2025 at 4:14 PM / IP Logged Link to Post Post Reply Quote lee.lopez
You're not being clear. Are you saying the blue LED is staying on constantly? Is is flashing? I'm wondering if you're in valet mode.
https://www.youtube.com/watch?v=hgHBfsPd728
albertkao
Member - Posts: 11
Posted: March 16, 2025 at 9:47 PM / IP Logged Link to Post Post Reply Quote albertkao
The LED is usually off (no light). When I press, release then press and hold the antenna programming button, the blue LED is staying on constantly. It does not start flashing. My remote cannot lock and unlock the car doors so it is not in valet mode. Anyway I press the lock and the lightning bolt at the same time but that do not fix the problem.
lee.lopez
Copper - Posts: 307
Posted: March 17, 2025 at 10:08 AM / IP Logged Link to Post Post Reply Quote lee.lopez
albertkao
Member - Posts: 11
Posted: March 23, 2025 at 2:20 PM / IP Logged Link to Post Post Reply Quote albertkao
The Honda OEM 1-way remote (transmitter) works !
Only the 2-Way LCD Remote does not work.
My control module is Autostart PS-4481TWS.
My 2-Way LCD remote is Autostart ASRS-7505.
Wednesday, April 15, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
