If you wish to post a reply to this topic, you must first login.
If you are not already registered, you must first register.
Monday, May 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
Unless you're dead set on going with an aftermarket unit, you might be able to use a t-harness from Axxess to connect your own sound processing equipment (AudioControl or JL Audio), amps, etc.
This will not be cheap. Idatalink maestro doesn't have anything listed either.
