2022 Chevrolet Malibu, Security Diagram For MooveTrax System
mazda 6t9
Member - Posts: 39
Posted: May 08, 2025 at 12:27 PM / IP Logged Link to Post Post Reply Quote mazda 6t9
I need a diagram for a Malibu. Installing a moovetrax system. I may use a idatalink ads-alca if needed. I may have to hit up the starter kill under the hood if it's like older Maliboos. 🤔
Thanks in advance
lee.lopez
Copper - Posts: 311
mazda 6t9
Member - Posts: 39
Posted: May 14, 2025 at 7:42 PM / IP Logged Link to Post Post Reply Quote mazda 6t9
Got everything but a true ignition wire for the starter kill. Can anyone double check the manual listed. I'm not sure where to find that. The wire idatalink shows only comes on AFTER started. I need one while cranking with the push to start.
Also the starter has 2 larger wires going to the solenoid. I interrupted both. But the module still needs true ignition.
lee.lopez
Copper - Posts: 311
Posted: May 14, 2025 at 8:59 PM / IP Logged Link to Post Post Reply Quote lee.lopez
How about an ignition relay under the hood?
2022 Chevrolet Malibu, Security Diagram For MooveTrax System - Last Post -- posted image.
