2003 Dodge Ram, CM900S Remote Start, No Air Condition
ovaldivia
Posted: May 13, 2025 at 11:13 AM / IP Logged Link to Post Post Reply Quote ovaldivia
i installed a CM900S compustar, remote start works, blower turns on after a few seconds but the compressor clutch or AC doesnt turn on to cool the air down. If i remote start it, then insert key and turn to Run, then AC and clutch engage and cools down. So do i send Accessory voltage to the Run wire of the Key switch? and which wire is the Run wire?
lee.lopez
Copper - Posts: 311
Posted: May 13, 2025 at 11:38 AM / IP Logged Link to Post Post Reply Quote lee.lopez
Have you checked the vehicle wiring section of this site? You can see your vehicle is listed as having 2 ignition wires and 2 accessory wires. All 4 should be powered during remote start:
https://www.the12volt.com/installbay/forum_posts.asp?tid=3971&tpn=1
ovaldivia
Posted: May 13, 2025 at 1:18 PM / IP Logged Link to Post Post Reply Quote ovaldivia
i will check when i get home. i do have accessory to the Blue wire and the Black/White wire. Not sure on Green wire or Orange wire. Is this where i should add two relays to seperate the wiring? or wire the accessory power from the cm900 to all four wires?
|        ACCESSORY|green & orange      |+ |ignition harness            |
| SECOND ACCESSORY|blue & blk/wht *7   |+ |ignition harnes
lee.lopez
Copper - Posts: 311
Posted: May 13, 2025 at 1:43 PM / IP Logged Link to Post Post Reply Quote lee.lopez
Yes, relays would be the way to go. Using an OP500, you could reprogram a couple POCs as negative accessory and ignition. Then use those to trigger your relays.
ovaldivia
Posted: May 13, 2025 at 8:47 PM / IP Logged Link to Post Post Reply Quote ovaldivia
i found the orange wire missing accessory voltage and now everything is working. i didnt have relays but added a fuse there seperated from the other 15 amp fuse. thanks for the help.
