1997 Dodge Ram 2500, Adding 451M, Unlock Doesn’t Work
mike450136
Posted: May 24, 2025 at 10:23 AM / IP Logged Link to Post Post Reply Quote mike450136
The switches inside still continue to work.
I got the lock button to function on the key fob but not unlock
Wired the 451m according to what was listed in the manual :
"wiring diagram c directly wired reversing polarity switch circuits."
I chose to wire the banvie as a negative trigger
As far as I understand it that's how it should be set up.but it doesn't unlock...
Banvie:
https://m.media-amazon.com/images/I/81zuLnf5aqL._AC_UF894,1000_QL80_.jpg
451m:
https://pdf.ampire.de/directed/451M_Installation_Guide_2451111.pdf
lee.lopez
Copper - Posts: 311
Posted: May 24, 2025 at 9:08 PM / IP Logged Link to Post Post Reply Quote lee.lopez
Have you tested and verified an unlock output from your Banvie unit?
mike450136
Posted: May 25, 2025 at 10:48 AM / IP Logged Link to Post Post Reply Quote mike450136
I had mistakenly tied into the orange/violet wire and the pink/violet wire and this must have put me in between the switches. I now am tied into the orange/black wire and the pink/black wire so now I'm in between the passenger switch and the motor. But it still didn't work. I swapped out the banvie unit out of another truck and low and behold it works! Thank you😁 I must have fried my banvie before I got the 451m
mike450136
Posted: May 25, 2025 at 11:32 AM / IP Logged Link to Post Post Reply Quote mike450136
Oops seems I've jumped the gun. only the driver side gets unlocked with the key fob not the passenger side
mike450136
Posted: May 25, 2025 at 1:18 PM / IP Logged Link to Post Post Reply Quote mike450136
Okay so I've tried wiring the Banvie and the 451m relay to the passenger side and now the passenger side works with a 30 amp fuse. driver's side does not work. it seems to have less power wired on the passenger side
mike450136
Posted: May 25, 2025 at 3:31 PM / IP Logged Link to Post Post Reply Quote mike450136
Okay got it fixed.The orange/voilet and pink violet on the driver's side are the ones to cut into for anyone who wants to know.
