Relationship Between Sensitivity and DB
BigJMan
Member - Posts: 22
Posted: June 25, 2003 at 10:17 AM / IP Logged
I have a question -
A couple of people have told me that the higher the sensitivity rating on a sub, the louder it will get in real life. Is this true? I though a 15" Subwoofer w/ a sensitivity rating of 96.4 Db just required more power than a 12" w/ a rating of 93 Db? I've noticed that, in general, the bigger you go in sub size the large the sensitivy number gets, so maybe it does have something to do with loudness. An Audiobahn's ABB123Q Triple Angle 12" Sealed Bass Box has a sens. rating of 102 Db. Does this mean it would be significantly louder than there dual 12" (99 Db)? Maybe I'm reading into this spec too much.
1992 Lincoln Towncar Cartier
4.6L SOHC Dual Exhaust
Stereo System - Working On It :)
bberman1
Gold - Posts: 2,314
Posted: June 25, 2003 at 10:43 AM / IP Logged
This is a long article but it will answer your ? + some http://www.eatel.net/~amptech/elecdisc/speaker.htm
BigJMan
Member - Posts: 22
Posted: June 25, 2003 at 11:16 AM / IP Logged
Very nice site, but could someone explain just the sensitivity rating in layman's terms?
tdsteele
Silver - Posts: 393
Posted: June 25, 2003 at 11:32 AM / IP Logged
I may be wrong but i had heard that the higher the rating the more efficient the speaker is, say one with a lower rating will require more power to do the same as the one with the higher rating with lower power, if that makes sense cause it looks funny to me...lol...anyways, could be wrong, had just heard that before.
BigJMan
Member - Posts: 22
Posted: June 25, 2003 at 11:48 AM / IP Logged
That's one of the many different things that I've heard before too.
bberman1
Gold - Posts: 2,314
Posted: June 25, 2003 at 12:04 PM / IP Logged
fuseblower
Silver - Posts: 403
Posted: June 25, 2003 at 12:18 PM / IP Logged
BigJMan, I agree with tdsteele, the sensitivity is the relative to the amount of power required to move the sub.  The higher the figure the less power needed to move the sub.
However, when comparing subs db only tells how efficient the sub is and this does not really equate into its' loudness.  Subs are designed to move air and the more air that is accurately moved the louder the sub will be.  I have heard a lot of stories about the Audiobahn's and they were all good stories..
But before you opt. for your subs listen to them at various levels with the type of music you enjoy listening to.  Some subs sound loud when you hear the music provided in the shops but are slopey when playing what you like..
Monday, June 10, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
