ford econoline flasher module
febisfebi
Posted: June 26, 2003 at 10:29 PM / IP Logged
my left blinker stays solid all the time, so i went to schucks and go a new flasher module, but i have no idea where to install it to. can anyone help?
thanks
febisfebi
Posted: June 26, 2003 at 11:12 PM / IP Logged
*"go" should be "got"
i found where to put it in, but my left blinker is still solid. anyone know what else could be wrong?
hotrodelectric
Copper - Posts: 112
Posted: June 27, 2003 at 10:45 AM / IP Logged
By solid, do you mean it doesn't flash? Check the bulbs front and back- if there isn't enough load to trip the flasher, it won't work. I'll hazard a guess and say the back one- have someone stand on the brakes, and check to see if your left rear lamp lights up. Also, make all the usual checks- sockets and wiring are still intact, the grounds are still OK, and so on.
chasesaccessori
Copper - Posts: 198
Posted: June 27, 2003 at 12:16 PM / IP Logged
If the lights are ok then it si probably the signal switch.
febisfebi
Posted: June 27, 2003 at 2:19 PM / IP Logged
yes i do mean they dont flash. just the left signal though. the right one is fine. the brake lights work, and parking lights work, so im pretty sure its not the bulbs. if its the switch, wouldnt it just not turn on at all?
I just did all the wiring checks, and everything seems fine. its both the front and the back signal flashers on the right, so im thinking its something internal more. any other suggestions?
thanks
powerdbysound
Posted: July 01, 2003 at 3:27 PM / IP Logged
What year is the van? if it's a older one it might just be a burnt bulb causing a sold flash on the leftside(if the right side still blinks) have a feeling your desribing a older van..that said there will be two flashers one for your turn signles and one for the hazzards
cheers
