Need 2003 Ford F150 alarm wiring
ramsfan
Member - Posts: 24
Posted: June 28, 2003 at 6:40 AM / IP Logged
Does anyone have alarm color codes for the 2003 f150 supercrew.Any help would be appreciated.
faqmat
Posted: June 28, 2003 at 7:52 AM / IP Logged
Battery : GREEN/ Purple
Ignition : Bleu/Green
Starter : RED / Bleu
ParkLights : Brown in driver Kickpad
Lock : PInk / YELLOW in driver Kickpad (neg) (if not equiped with keyless, doorlock are reverse polarity!!)
Unlock : Pink/Green in driver kickpad (neg) (if not equiped with keyless, doorlock are reverse polarity)
Door Trigger : BLACK/ Blue in passenger kick panel or BLACK/ Pink (neg)for driver door and BLACK / YELLOW (neg) for all other doors, located in a gray connector in the top left corner of the fuse box.
ramsfan
Member - Posts: 24
Posted: June 28, 2003 at 8:01 AM / IP Logged
Thank for your reply.
ramsfan
Member - Posts: 24
Posted: June 28, 2003 at 8:06 AM / IP Logged
I wanna install window modules on the alarm.Are there any relays needed to be added and does any one know the wire codes.
Platinum - Posts: 12,488
Posted: June 28, 2003 at 8:09 AM / IP Logged
You will need window modules for this and also you will require a latched or a 6 - 10 second pulsed output from your alarm. Here is the wire colors for the Ford:
|  LF WINDOW UP/DN|wht/blk - tan/lt blu|A  |driver window switch        |
|  RF WINDOW UP/DN|wht/yel - tan/lt blu|A  |driver kick panel           |
|  LR WINDOW UP/DN|gry/org - yel/lt blu|A  |driver kick panel           |
|  RR WINDOW UP/DN|yel/blk - RED / blk   |A  |driver kick panel           |
