Mitsubishi Spacewagon 1997
noelmoore
Posted: July 11, 2003 at 3:21 PM / IP Logged
Can anyone help with a wiring diagram for a Mitsubishi Spacewagon 1997?  I am trying to correct a wiring error with a Cobra 6422 alarm.
Noel
apursell
Member - Posts: 22
Posted: July 30, 2003 at 12:37 AM / IP Logged
hrmm 92 spacewagon, for UK...
|              12V|                    |   |                            |
|          STARTER|BLACK / YELLOW        |   |ignition harness            |
|   SECOND STARTER|                    |   |                            |
|         IGNITION|BLACK/ white *1      |   |ignition harness            |
|  SECOND IGNITION|                    |   |                            |
|   THIRD IGNITION|                    |   |                            |
|        ACCESSORY|blue or white       |   |ignition harness            |
| SECOND ACCESSORY|                    |   |                            |
|       POWER LOCK|BLACK/ blue          |-  |CDL relay under o/s dash    |
|     POWER UNLOCK|brn/yel or grn/blk  |-  |CDL relay under o/s dash    |
|       LOCK MOTOR|                    |   |                            |
|     UNLOCK MOTOR|                    |   |                            |
|    DISARM DEFEAT|                    |   |                            |
| PARKING LIGHTS +|grn/red & grn/blu   |   |under the steering column   |
| PARKING LIGHTS -|                    |   |                            |
|       HEADLIGHTS|                    |   |                            |
|     DOOR TRIGGER|                    |-  |at the interior light       |
| DOME SUPERVISION|                    |   |                            |
|  TRUNK/HATCH PIN|                    |   |                            |
|         HOOD PIN|                    |   |                            |
|TRNK/HTCH RELEASE|                    |   |                            |
|  FCTRY ALARM ARM|                    |   |                            |
|FCTRY ALRM DISARM|                    |   |                            |
| DISARM NO UNLOCK|                    |   |                            |
|       TACHOMETER|                    |   |                            |
|      SPEED SENSE|                    |   |                            |
|       BRAKE WIRE|                    |   |                            |
|     HORN TRIGGER|                    |   |                            |
|           WIPERS|                    |   |                            |
|  LF WINDOW UP/DN|GREEN/ red           |   |                            |
|  RF WINDOW UP/DN|BROWN / yellow        |   |                            |
|  LR WINDOW UP/DN|BROWN / green         |   |                            |
|  RR WINDOW UP/DN|BROWN / blue          |   |                            |
| SUN RF OPN/CLOSE|                    |   |                            |
|   SUN ROOF LIMIT|                    |   |                            |
|        RADIO 12V|                    |   |                            |
|     RADIO GROUND|                    |   |                            |
|     RADIO SWITCH|                    |   |                            |
| RADIO ILLUMINATE|                    |   |                            |
|    POWER ANTENNA|                    |   |                            |
|       LF SPEAKER|                    |   |                            |
|       RF SPEAKER|                    |   |                            |
|       LR SPEAKER|                    |   |                            |
|       RR SPEAKER|                    |   |                            |
Notes:
*1 Fuel pump wire is yellow wire in the o/s front sill harness.
