car subwoofers in home
superproducer34
Posted: August 07, 2003 at 2:18 PM / IP Logged
I have a funny question yall might think its stuped but I was wondering how would I power a car amp in  my home to run two 12" subs, what would I need? Thanks for all your help.
ViperATC5
Copper - Posts: 202
Posted: August 07, 2003 at 8:04 PM / IP Logged
a power supply capable of tranforming household AC to 12v DC in the correct amount of amperage for your amp
Laur
Copper - Posts: 65
Posted: August 10, 2003 at 2:30 PM / IP Logged
You will need a very big power supply .
But you can conect the subs to a home amplifier .
DYohn
Platinum - Posts: 10,741
Posted: August 15, 2003 at 7:45 PM / IP Logged
I would suggest you use a home amplifier.  Running a car amplifier in your house is possible, but the power supply system you would need is more expensive than buying a good "indoor" amp would be.  I use a set of older Infinity Beta 10's in my house now, by the way, powered by an old Phase Linear amp I had sitting around... Sounds great.
Nocturnal
Copper - Posts: 85
Posted: August 27, 2003 at 10:41 PM / IP Logged
You may want to mind impedance matching.  A lot of car audio components are designed for 2 or 4 Ohm, while the typical home stereo is 8 Ohm.  This mismatch will make your home stereo amp very unhappy over time.
defective
Silver - Posts: 642
Posted: September 02, 2003 at 7:46 AM / IP Logged
Yeah, Listen to Nocturnal....... i fried a Harmon amp that way......    great for testing but not a long term decision unless you bridge it right.....  grin..  now i gotta buy a new reciever.
Monday, February 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
