1993 Nissan Pathfinder With Sock Amp
sr20det
Posted: August 27, 2003 at 7:41 PM / IP Logged
Tryin to put  a deck into a 93 pathfinder with factory clarion amp.  Can't figure it out to save my life.!!! it has 8 speaker system and clarion amp behind factory radio any clues to what the speaker leads are i got the power and ground.  it is a full  load with power windows locks and the whole nine yards.  Tweets in the window pillars and 6x9 in the front doors also 6x9 in the rear roof with seperate tweets in the same place.  i have never had one like this any help would be great it is  a 4 door as well.
If in doubt turn up the BOOST!!!!
davidejennings
Posted: September 02, 2003 at 2:08 PM / IP Logged
 I ran in to the same problem this weekend. I have decided to run all new speaker wire. I am installing a new 4 channel amp as well. I will still use the power/remote/pwr ant stuff. I never found the amp to debug the wiring and by-pass the amp. Although it might be easier than running the new wires through the door groments. The back speakers are not that hard. If you find the amp's location let me know and I will do the same.
David
banderson
Posted: September 08, 2003 at 9:24 PM / IP Logged
First I found the Amp is under the drivers seat. Second You have to have the Amp on to do anything to change out the radio and configure the speakers.I have the Hayes Service manual and the wiring diagram just sux.  I found the pin out to the factory wiring harnes and connector at www.installdr.com. I dont remember the exact search but I got the pin out in a PDF file.  Once I got the Amp powered, the rest was easy
