Should a sealed box be divided for 2 sub?
fishing
Member - Posts: 27
Posted: August 31, 2003 at 10:16 PM / IP Logged
Should a sealed box for 2  subs be divided in the middle? Or open?
12 volt rules
tdsteele
Silver - Posts: 393
Posted: August 31, 2003 at 10:21 PM / IP Logged
I've seen it done both ways, but i think its always better to have the divider so the subs have their own space to do their thing.
DYohn
Moderator - Posts: 10,741
Posted: September 01, 2003 at 8:49 AM / IP Logged
If you are running two woofers in parallel or in series where both see the exact same signal (mono) they can be mounted in the same air space.  Be sure when you design the enclosure to build it for TWO speakers!  If you want to run different signals to the two woofers (i.e. run them in stereo) they must be mounted in their own air space (divided.)
IronCy
Copper - Posts: 93
Posted: September 01, 2003 at 9:08 AM / IP Logged
also,
if you are running each sub off of its own amplifier, it is recommended that each woofer have its own chamber.....otherwise, shared air space is fine.
-Cy
wvsquirrel
Gold - Posts: 1,237
Posted: September 02, 2003 at 6:31 AM / IP Logged
It's easier to design/build if each sub is in it's own chamber.
Squirrel
"No more Cpt. Kirk chit chat"
Donate to the12volt.com
bberman1
Gold - Posts: 2,314
Posted: September 02, 2003 at 12:04 PM / IP Logged
Whenever I build and enclosure I always use separate chambers, it doesn’t take allot of time or materials to make the center divider. Just to name a few of the benefits. If you install the center divider it acts as a brace so you end up with a stronger box. If you have a problem with one sub it doesn’t affect the other. And in larger enclosure it helps to reduce wave cancellation.
Thursday, July 17, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
