What Relay to use?
chall
Posted: September 04, 2003 at 6:15 PM / IP Logged
I need a relay that will drive (2) 12 vdc solenoids.  The circuit that drives the relay will be supplying the coil with about 200mA and 10-12 vdc.  I dont know how much contact voltage a normal solenoid needs and I dont know what kind of relay will drive both solenoids(spdt,dpdt,etc...).  Any help on this subect will be greatly appreciated.  I also need to know how to wire relays.
Thanks,
I know just enough to be dangerous to myself
auex
Platinum - Posts: 5,041
Posted: September 04, 2003 at 7:48 PM / IP Logged
What exactly are you trying to do?
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
chall
Posted: September 06, 2003 at 5:59 PM / IP Logged
what im trying to do is a bit complicated and goes into some depth, i just need to drive open 2 solenoids for a given amount of time and the circuit i'm using wont supply enough current to directly open two solenoids(I think) so i need to use a relay or so i've been told,  I don't have any expierience with relays or solenoids so i'm at a stand still until can figure it out
