2 comp 12s and an 800w amp
flatulatta
Silver - Posts: 356
Posted: September 20, 2003 at 9:47 PM / IP Logged
k ma friend is running an 800w amp 2 his 2 comp 12s they are rated at 150 rms and 300w max and it soundsl ike its conastnatly bottoming out this is from the overpowering correct and how long does someone think itll be b4 they blow?
bfog99
Copper - Posts: 212
Posted: September 20, 2003 at 10:40 PM / IP Logged
What is the amp he is running? Not all amps put out what they say they do. It also depends on the voltage of the car. I am assuming the 800w is the peak value. If it is the peak, then it is 400 per channel and 200W RMS per sub. Might not be the best, but might not necessarily blow them. If it is 800 W RMS, then he should be blowing them any time soon. It really depends on the amp and how clean the signal is to the amp.
flatulatta
Silver - Posts: 356
Posted: September 20, 2003 at 10:48 PM / IP Logged
well he said 800w rms is wut i assume it think its like us acoustics or something he said it was sh*tty but it really sounds like there bottoming out reall bad
bfog99
Copper - Posts: 212
Posted: September 20, 2003 at 10:56 PM / IP Logged
US Acoustics is actually not that bad of am amp. They are rated at what they put out. If it is something like Legacy or something like that, then it probably doesn't put out what it says. Legacy is known for putting out about 1/4 of what it says. There is no way to put a date or time on when they will blow. But it is not good. He is way over powering them. It is only a matter of time. Easiest solution is to buy a new amp. My suggestion is the JBL BP 300.1. He can wire them to 2 ohm and push 300 W RMS. Perfect match.
flatulatta
Silver - Posts: 356
Posted: September 20, 2003 at 11:02 PM / IP Logged
yea im gettin a jbl 600.1 for my kicker comp vrs i figured hed blow em
nedgeworth
Silver - Posts: 264
Posted: September 21, 2003 at 12:32 AM / IP Logged
He won't blow them unless he's gain happy and it sounds like he is if he's letting them bottom out. If your going to overpower speakers you just have to be very cautious with your gain settings.
flatulatta
Silver - Posts: 356
Posted: September 21, 2003 at 7:19 AM / IP Logged
yea i think he may have them maxed out but im not sure imma have to check it out for him
