benz
rahmirp1
Posted: September 21, 2003 at 12:49 PM / IP Logged
1993 190 benz. Trying to install a aftermarket radio and cant get all speakers to work. Has factory amp and the only 2 speakers in dash are the only speakers working any info would be great thanks
rahmir pierce
StealthEs
Copper - Posts: 326
Posted: September 21, 2003 at 4:01 PM / IP Logged
Just hard wire the 12v, ground, ACC, and antenna from the deck. For the speakers just run your own wires to each. Shouldn't take you more then 2 hours, taking your time.
Cris
CruisinS&S
Copper - Posts: 225
Posted: September 24, 2003 at 5:52 PM / IP Logged
does he have a factory Bose amp in the driver side under the trunk?If so I will give you the speaker colors.Is there an antenna plug behind the radio??Usually in the trunk
Cruisin Security And Sounds
CruisinS&S
Copper - Posts: 225
Posted: September 24, 2003 at 5:55 PM / IP Logged
I just reread your post that said that you DO have a factory amp. Is it the Bose system?Might not be a good idea to wire all the speakers seperately from the new deck directly to your stock speakers. Some of these cars have a crossover that you need to retain and incoperate into the new system or else you will get all unwanted freq. through every speaker
Monday, February 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
