94 camry
flatulatta
Silver - Posts: 356
Posted: September 22, 2003 at 7:37 PM / IP Logged
im trying to install my subwoofers in my car and i cant seem to find a hole to run my power wire from the battery back to the amp any help would be great
italnpimp59
Silver - Posts: 427
Posted: September 22, 2003 at 10:59 PM / IP Logged
drill a hole and use a rubber grommet...but be VERY careful that once you drill thru the firewall that you dont hit anything you're not supposed to!!!
profuse007
Gold - Posts: 2,015
Posted: September 22, 2003 at 11:54 PM / IP Logged
there is a factory gromet if you look under the dash upleft, might fit through there. poke the crap out of that gromet to get it through(just exaggerating). i think there is not enough room under there to drill nor from the hood.
Houston,TX
flatulatta
Silver - Posts: 356
Posted: September 23, 2003 at 2:10 PM / IP Logged
yea i think i found what yall are talking about but the wires run through the upper part of my wheel hub
flatulatta
Silver - Posts: 356
Posted: September 23, 2003 at 8:12 PM / IP Logged
k thankx guys i found it i had to take off the plastic inside my wheel well if anyone needs help with it lemme know ill try 2 get pix for u it wasnt hard at all ive got it pretty horridly installed though like none of the wires are under the carpet
