Bulb-out feature with relay
1998k
Posted: November 27, 2003 at 2:45 AM / IP Logged
Dear guys, please an help. I'm planning to install gauge10 cable size and relays for high and low beam. Mine is a Mercedes 1998 C Class (W202 series). Please how can I avoid "bulb-out" lamp in the dash? I'd like to keep this feature for rear bulb, so avoiding to take out the bulb from the dash.
Please any chance to solve the matter?
Thanks a lot for any input
superchuckles
Copper - Posts: 89
Posted: January 01, 2004 at 6:42 PM / IP Logged
i don't see how you're going to do this with simple relays, unless maybe you do something like tie a relay in series with a 6 volt bulb..... bulb blows, relay won't turn on, which would leave the relay in the NO position for the power to go thru (and light a bulb on your instrument panel).  even then, you'd have to work it so that the relay's coil pulls the same resistance as the bulb in the "on" state (bulbs have a consideribly higher resistance when lit than when off).   the way you are most likely going to have to do it is to either find or build yourself a current sensing circuit for each bulb you want an indicator on (for the regular tail lights, not brakes or turn signals, you could build one current sensing circuit that would  detect when less current is being drawn than usual when any one of the regular tail lights are out).  it should be much simpler though if you build a circuit for each and every bulb independant from every other one - that way it can be a "go /no go" scenerio.... any current draw = good bulb, zero current draw = bulb blown = open circuit.   if you still need it, later i might toss together a couple of op amps in a few examples for some simple bulb out current sensing circuits if nobody else does.
1998k
Posted: January 05, 2004 at 1:51 AM / IP Logged
Thanks a lot superchukles,
I've appreciated your help.
Hi
