2003 and 2004 Dodge Ram's
daniel2002p
Silver - Posts: 524
Posted: November 27, 2003 at 4:01 PM / IP Logged
Does anyone have this problem as well?
When I install a alarm in this vehicle (the 6cyl, 8cyl, or HEMI) the Engine Light comes on and requires a trip to the dealer to be fixed.  The Last alarm w/remote start I have put in a 2004 Ram with the 8cyl and the3 light came on.  It cost our shop $75 to get code erased and delaer said computer has nothing to report, but light came on.  Anyone else have that same problem.
BTW: It does the same weather the unit is a alarm, or alarm w/ remote start.
2005 Toyota Corolla S
    1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
auex
Platinum - Posts: 5,041
Posted: November 27, 2003 at 4:15 PM / IP Logged
Did you power up all the ingition wires?
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
securinu
Silver - Posts: 772
Posted: November 27, 2003 at 5:58 PM / IP Logged
you can get a code scan tool that resets lights at local autoparts store  for about $150 . we all make mistakes from time to time and forget to power up a wire but for $150 its cheap insurance and the customer never needs to know anything that wont ultimately hurt the vehicle.  just my $.02
Joe O'Byrne
Owner / Installer
daniel2002p
Silver - Posts: 524
Posted: November 27, 2003 at 8:48 PM / IP Logged
It is not only with remote starts (and yes all the ign wire are powered up) but also with just an alarm?  Any other clues???
    1.8L VVT-i I-4
chpsk8
Member - Posts: 12
Posted: November 27, 2003 at 10:59 PM / IP Logged
My installer had to power all the ingnition wires in order to get my check engine light off. I had two where the wiring diagram showed one. Confused them pretty good. I had a Compustar model installed and it took a couple trips to get it right. My problem was if I used the autostart the check engine light went on. Then I had to disconnect the battery to reset it. After powering all the ignition wires the probelm went away.
03zx3
Member - Posts: 23
Posted: November 27, 2003 at 11:32 PM / IP Logged
Wire/FunctionColourLocation/DescriptionPolarity
PASSIVE ANTI-THEFT YES TRANSPONDER SEE NOTES
12 VOLTS RED / white or Pink/black Ignition switch harness +
IGNITION Blue (smaller of 2) Ignition switch harness +
IGNITION 2 RED / white* Ignition switch harness +
ACCESSORY Orange Ignition switch harness +
ACCESSORY 2 Green Ignition switch harness +
STARTER Yellow Ignition switch harness +
TACH BLACK/ gray or RED / black At coil on right side of engine** AC
FUEL INJECTOR Opposite of Dk.GREEN/ orange At any injector on engine AC
LOCK WHITE/ green*** In driver's kickpanel -
UNLOCK WHITE/ green*** In driver's kickpanel -
DRIVER LOCK MOTOR Tan/pink In driver's kickpanel +
DRIVER UNLOCK MOTOR Blue In driver's kickpanel +
PASSENGER UNLOCK MOTOR Tan/orange In driver's kickpanel +
DOORPIN SEE NOTES*****
FACTORY ARM Lt.GREEN/ orange*** In driver's kickpanel -
FACTORY DISARM Lt.GREEN/ orange*** In driver's kickpanel -
BRAKESWITCH WHITE/ tan At switch on brake pedal bracket +
PARKLIGHTS Violet / YELLOW**** At light switch harness -
HAND BRAKE WHITE/ green At switch on handbrake lever -
HORN BLACK/ red At steering column -
DRIVER WINDOW UP White At switch in driver's door REV POL
DRIVER WINDOW DOWN Lt.blue At switch in driver's door REV POL
PASSENGER WINDOW UP BROWN / white In driver's kickpanel REV POL
PASSENGER WINDOW DOWN Violet/white In driver's kickpanel REV POL
LEFT REAR WINDOW UP Dk.blue/white In driver's kickpanel REV POL
LEFT REAR WINDOW DOWN RED / black In driver's kickpanel REV POL
RIGHT REAR WINDOW UP Gray/black In driver's kickpanel REV POL
RIGHT REAR WINDOW DOWN Dk.GREEN / WHITE In driver's kickpanel REV POL
HEADLIGHTS WHITE/ dk.green At lieft headlight assembly +
REVERSE LIGHTS Violet/black Under driver's side running board +
VSS WIRE WHITE/ orange Pin-27 of 32-pin plug on PCM******
KEY SENSE Lt.blue At steering column -
2003 and 2004 Dodge Ram's - Last Post -- posted image. Vehicle notes
PLEASE NOTE: For the Ram 2500 and 3500, see the Dodge Ram 2500,3500 pickup 2002 in the database. This vehicle may be equipped with a TRANSPONDER passive anti-theft system. If the vehicle has GRAY ignition keys, see the appropriate diagram before any remote start installation.
* This wire is not always present, but if it is there, it must be connected or the check engine will come on.
** On the 3.9L, 5.2L and 5.9L engines, the tach wire can be found at the coil on the engine near the distributor. On the 8.0L V10 engine there are 2 coils packs on the right side of the engine. Use the BLACK/ GRAY at the 6-pack for a 2 cylinder reference.
*** This is a 1-wire system with resistors. If the vehicle is equipped with factory security, use the LT.GREEN/ ORANGE wire (2-Kohms for lock/arm and 480-ohms for unlock/disarm). A double pulse to unlock all doors. With no factory alarm, use the WHITE/ GREEN wire (815-ohms for lock and 315-ohms for unlock). Both wires are located in the driver’s side kickpanel. Relays should be used to insure a good ground to the resistors. See the doorlock diagram for exact wiring instructions.
**** Ground through a 330-Ohm resistor to activate parklights. You can also use a BLACK / YELLOW (+) in the large harness under the hood between the driver's side fender and the firewall.
***** Driver's door is TAN, Passenger door is TAN/RED, right rear is TAN / YELLOW and left rear is VIOLET/ORANGE. All 4 wires are found in a plug above the brake pedal. Diode isolate with 1N4001 diodes if connection together.
****** On right side of firewall in engine compartment.
03zx3
Member - Posts: 23
Posted: November 27, 2003 at 11:33 PM / IP Logged
hey just posted the colors look at vehicle notes.
Monday, July 7, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
