2001 Corvette Z06 VSS?
enrengiil
Posted: December 29, 2003 at 10:05 PM / IP Logged
So i know that the VSS wire for the 01 vette is GREEN / WHITE at the computer under the hood behind the tire next to the battery.  But I was in there and there were at least ten to fifteen different GREEN / WHITE wires within a foot of each other.  Can anyone be more specific as to where the VSS wire is.  Is it under the Fuse/Realy center, or under the battery, or maybe in a harness with X amount of wires with it.  I would greatle appreciate the help.  My customer has been very patient with the delay, but his limit is quickly aproaching
2001 Corvette Z06 VSS? - Last Post -- posted image.
auex
Platinum - Posts: 5,041
Posted: December 29, 2003 at 11:07 PM / IP Logged
You need to test for it. Place the red lead to constant +12V, and take the black lead to each of the GREEN / WHITE wires, then roll the car back and forth about ten feet. The wire you want is the one that goes between nothing and a ground. The wire may also be at the radio.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
sparkie
Platinum - Posts: 2,061
Posted: December 30, 2003 at 8:16 PM / IP Logged
There are two plugs for your engine computer. The VSS wire is in position 50 of the red one. The plug must be removed to see the color. If you take the cover off the back of the plug the pins should be labeled with numbers.
sparky
