2001 cavalier remote start
rasianrocket
Posted: January 04, 2004 at 3:33 AM / IP Logged
2001 cavalier remote start wiring please2001 cavalier remote start - Last Post -- posted image.
thanks
Bnluis
Silver - Posts: 578
Posted: January 04, 2004 at 3:45 PM / IP Logged
CHEVROLET CAVALIER 2000 - 03
WIRE COLORSLOCATION
12 VOLTS CONSTANTREDIGNITION SWITCH HARNESS
IGNITION 1PINKIGNITION SWITCH HARNESS
ACCESSORY /HEATER BLOWER 1ORANGEIGNITION SWITCH HARNESS
STARTERYELLOWIGNITION SWITCH HARNESS
PARKING LIGHTSBROWNDRIVERS KICK PANEL HARNESS to the REAR
DOMELIGHTGREEN/ BLACK & LT. BLUE ( - )SEE NOTES *1  & *2
PWR DOOR LOCKLT. BLUEEITHER KICK PANEL *3
PWR DOOR UNLOCKWHITEFACTORY KEYLESS (TYPE A)   W/O FACTORY KEYLESS (TYPE C)
TRUNK RELEASEBLACK/ WHITE (+)@ BCM *2
TACH SENSORVIOLET/WHITE (AC)@ ENGINE HARNESS *4
BRAKEWHITE (+)@ BRAKE SWITCH
HORNGREEN or BLACK ( - )@ STEERING COLUMN
FACTORY DISARM   N/A
FACTORY ANTI-THEFT TYPEPASSLOCK II
NOTES:
*1 - The GREEN/ BLACK is located in the lower driver kick panel. It catches the driver door only.  The LT. BLUE is located in the passenger kick panel and it catches the passenger door. Tap both wires and diode isolate each. Also found at the BCM.
*2 - The BCM (Body Control Module) is located to the left of the steering column above the driver kick panel.
*3 - On vehicles without keyless entry, locks are 5 wire (type C) and are mastered from the passenger side switch.  On vehicles that do have factory keyless, the locks are positive trigger (type A). Also found at the BCM
*4 - The engine harness is found next to the battery, below the radiator hose, just above the transaxle.
Luis
Sound Waves
Is up to the installer to test all wires with a DMM whenever possible.
