1994 Cutlass Ciera head light fuse
Deanna_hays
Posted: January 23, 2004 at 7:23 PM / IP Logged
how do you change the fuse for the head lights.  Manufacturer recommends dealer, but can you do it your self?
tblanning
Copper - Posts: 60
Posted: January 23, 2004 at 8:28 PM / IP Logged
if you have the owners manual it should show you all the fuses and location of the fuses usually they even show you the type of fuse you need
Deanna_hays
Posted: January 24, 2004 at 11:24 PM / IP Logged
The head light fuse is not in the fuse box.  That is the problem, can't find it.
mobiletoys2002
Gold - Posts: 1,050
Posted: January 25, 2004 at 12:29 AM / IP Logged
check the fuse box in the engine bay near thre battery!
bigslammy
Member - Posts: 10
Posted: January 25, 2004 at 11:25 AM / IP Logged
It doesnt have a fuse for the headlites it has a fuse link that powers the headlamp switch.Alot of cars do have fuse for the headlamp but not yours.
mobiletoys2002
Gold - Posts: 1,050
Posted: January 25, 2004 at 12:48 PM / IP Logged
   check the fusible links as well one may be blown!!These should be in the fuse panel near the battery in th eengine bbay !
