Fiberglass Basics
nyguy4u
Copper - Posts: 148
Posted: February 03, 2004 at 12:57 AM / IP Logged
Well thanks to all your guys help on my past posts.. I know what i'm doing now thanks to you guys.. and before I do it, I just want to tell you guys what im gonna do and please let me know if im wrong..
First off.. I have 3 15"s. I'm going to get 3/4 MDF, make a sealed enclosure, and not chamber it.. but brace the hell out of everything, especially the rings. I plan on permanently bracing the rings as well just for piece of mind.
Now, as for the fiberglassing part.. I think i'm right about this.. but please, if I am.. or if there is a better suggestion.. please let me know. Here are the steps I plan on taking unless i'm told other wise...
- Wrap cotton (tshirt material).. and resin it.. let it dry, but not completely.
- Wrap again with fleece.. resin it.. let it dry completely!
- After resin is fully dry.. time to fiberglass. Fiberglass from the inside. About 6 or 7 layers of fiberglass to make sure it can handle the weight of 3 very heavy 15"s
- Glop Bondo and spread on the entire outter box.. sand.. bondo.. sand bondo.. however many times it takes to get smooth.
- Spray on a few light coats of primer.. paint.. then some layers of clear coat
Thats the steps I plan on taking. My main questions are. I heard its MUCH easier to fiberglass on the inside.. is that true?. Also, is 7 layers too much or too little for 3 subs?.. and finally.. what kind of fiberglass do I use for the 7 layers?. I saw there is chop mat.. and some that are different ounces. Which do I use??.
Like I said.. any help is appreciated.
Thanks!!
Teamrf
Gold - Posts: 1,031
Posted: February 03, 2004 at 3:14 AM / IP Logged
I was always told to let the resin dry completely before reapplying anything.
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
geepherder
Platinum - Posts: 3,668
Posted: February 03, 2004 at 12:11 PM / IP Logged
First I have the bottom of the box molded to the car with plenty of layers for strength.  After I stretch and resin, I fiberglass the outside of the box (over the fleece).  I've heard about laying inside, but have never tried.  7 layers should work fine.  Test it out before finishing the outside to make sure you're happy with it.  Then you can add more if desired before you bondo, etc.  I use one-and-a-half ounce mat.  I ordered a 6" wide roll for around $26 from www.shopmaninc.com.
beyondamfm
Copper - Posts: 105
Posted: February 03, 2004 at 12:22 PM / IP Logged
sounds like a good start. Make sure to keep us posted a put up pics every once and awhile.Fiberglass Basics - Last Post -- posted image.
The Clear Bra Guy
KCs premiere paint protection guru
soup
Copper - Posts: 79
Posted: February 03, 2004 at 12:52 PM / IP Logged
7 should be plenty, but if you have trouble fiberglassing on the inside, and are a little worried about strength, just add a few layers on the outside, or if you are worried about not getting it smooth enough, then add some kitty hair bondo on the outside.
7 layers if you use mat will definately be enough though, I am 230 pounds and I am sure I could jump on it. If you use cloth, it should still be enough, I dont have much experience so dont take this to heat, but I would say about 4 layers of mat, then add kitty hair to the corners. You prolly know this allready, but its real important so I might as well say it again, air bubbles will cause major problems, make sure taht you have all bubble out.
