2001 hyundai accent Brake wire
Dalmation
Posted: February 03, 2004 at 11:30 AM / IP Logged
ive installed a bulldog security remote starter and seem to be having trouble with it... i just want to make sure i have the right wire...  i am using the pink and black wire that follows from the brake pedal...
Dalmation rhymes with Nathan?
Teamrf
Gold - Posts: 1,031
Posted: February 03, 2004 at 4:37 PM / IP Logged
If you don't have a tech sheet...use a DMM to find the voltage on that wire you have. Verify that is the correct wire.
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
Teamrf
Gold - Posts: 1,031
Posted: February 03, 2004 at 4:40 PM / IP Logged
I think you have the wrong wire...look up there for a green wire. It should be right above the brake pedal...remember to test with a DMM.
~The Rookie~
