DEI 451M Problem, Need help
Sebastian018
Silver - Posts: 364
Posted: February 03, 2004 at 10:59 PM / IP Logged
HI, I just bought a Clifford RSX3.5, Which comes with the DEI 451M, for the power door locks, My car is a mercedes 190e with Vacuum System. . the 451M Have 3 pin plug that goes to the alamr module and 5 wire harness.
which are>
Violet/Black: Lock Unlock
              Normally open #87
GREEN/ Black: Lock Output #30
WHITE/ Black: Lock Normally Closed #87A
Blue/Black: Unlock Output #30
BROWN / Black : Unlock Normally Closed #87A
I have try every single way to connect it, but I can het it to work, I can Only make one work, either lock or Unlock but not both, I m kind of lost..
When I used to Have the prestige APs-996 I have it connect using two relays , the one I got on this website.. But Now it didnot work.
PLEASE Help me
Bnluis
Silver - Posts: 578
Posted: February 03, 2004 at 11:38 PM / IP Logged
follow the instructions that came with the 451m, The car has vaccum doorlocks and you also have to programm you alarm for 3.5 second door lock pulses.
DEI 451M  Problem, Need help - Last Post -- posted image. Vacuum Type Door Locks
Found mostly on Mercedes Benz vehicles, the movement of the door lock actuators is controlled by a central vacuum pump. The switch changes polarity on a single wire that may rest at power or ground depending on the state of the door locks. You can duplicate this with at least a 2 second pulse. If the alarm or keyless entry you are installing does not have a 2 second or longer duration option for the door lock outputs, do not use this diagram (it will not work unless you incorporate a timer into this circuit).
Luis
Sound Waves
Is up to the installer to test all wires with a DMM whenever possible.
sroth140
Silver - Posts: 513
Posted: February 03, 2004 at 11:41 PM / IP Logged
take and cut the PURPLE / black and ground it. take purple to 12v.  program the 3.5 to 2second pulse.  ummm.... i cant remember the rest of the terminals and what colors they are...  i know its GREEN/ black, blue/black, BROWN / black, and WHITE/ black.  my copy of the 451m wiring is in my tool box at work and i know the .pdf from directed is down.  the diagram should help you finish it there, ill bring a copy of the M home and see if you need more help.
Sebastian018
Silver - Posts: 364
Posted: February 04, 2004 at 7:17 AM / IP Logged
              Normally open #87
I will try doing it now, thank you
