99 Chevy S10 DRL
beaugt
Posted: February 07, 2004 at 4:51 AM / IP Logged
How can i disable the daytime running lights on a 99 Chevy S10 2.2L. Ive got a diagram off Shopkey. Traced it around. Tried to locat the body module control thats on the side of heater case where should be a white wire that "should" open the circuit that runs the DRL. No luck finding it. So then looked for the switch on the E brake "since when ebrake is on the DRL is off" nothing. Then just pulled the relay switch and realized that my H Beam light is connected with that. Do any of you know of any other way to accomplish this ive done everything but call a GM engineer..Thanks
georgecato
Posted: February 09, 2004 at 1:24 PM / IP Logged
Press your dome light override switch on and off about 3 times in 2 seconds.  The same steps will enable the DRL.
SVrider
Member - Posts: 12
Posted: February 09, 2004 at 2:26 PM / IP Logged
Why would you want to disable your DRL? Its there for safety reasons and makes you more visible to other drivers.
-Chris
2001 Suzuki SV650
beaugt
Posted: February 10, 2004 at 12:03 PM / IP Logged
the dome overide switch trick only works for '00-up models.  why disable it? I just dont like it. safety isnt a concern to me here in california people are still to busy on theyre cell phones to notice you anyway.
