maxima horn not working!
Loveforyou
Member - Posts: 39
Posted: February 10, 2004 at 7:17 PM / IP Logged
I have 95 maxima the horn doesn't work . check 10a fuses is good and i have try jumper wire from relay to horn is working so i know the relay is working .can anyone help me please i have take the airbag off but i can't find the horn switch for it. if someone know please help thank
Teamrf
Gold - Posts: 1,031
Posted: February 10, 2004 at 10:44 PM / IP Logged
Well you probably don't have to go through all of that to find your horn wire. Just look under your steering column. All the wires are there. Find out what color the wire is, and locate it under there..
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
Teamrf
Gold - Posts: 1,031
Posted: February 10, 2004 at 10:46 PM / IP Logged
The color of your horn wire is suppose to be GREEN / WHITE according to this tech sheet I'm looking at.
~The Rookie~
Loveforyou
Member - Posts: 39
Posted: February 11, 2004 at 5:00 AM / IP Logged
thank you
Monday, February 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
