Timer design
old guy
Member - Posts: 7
Posted: February 14, 2004 at 9:33 AM / IP Logged
I need to make a timing circuit to turn on the high idle function on a diesel engine.  I know what lines to tap into, just not sure about putting together a simple timer.  It's been 25 years since I have done much electronic work.   I need to have the timer trip a 12V relay.   Can anyone give me a quick and dirty or point me in the correct direction?  Thanks,
jc
Wasilla, Alaska
tonto26
Member - Posts: 41
Posted: February 18, 2004 at 10:33 PM / IP Logged
Heres the best way I can think of:
You can design your own circuit using a 555 timer. Check out these basics
http://www.circuit-innovations.co.uk/555.html
use a monostable timer setup, just have the output engage a relay
more info:
http://ourworld.compuserve.com/homepages/Bill_Bowden/555.htm
xetmes
Silver - Posts: 586
Posted: February 19, 2004 at 5:54 AM / IP Logged
how long do you want it on and off?
for moderate time intervals the 555 as mentioned above might be the best, or you could use a microcontroller if you are lazy like me Timer design - Last Post -- posted image.
Sunday, December 21, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
