92 honda accord
do0dfromcali
Member - Posts: 11
Posted: February 18, 2004 at 9:22 PM / IP Logged
Need a wiring diagram for a 92 honda accord 2 door 5 speed
atwageman
Member - Posts: 43
Posted: February 19, 2004 at 3:58 AM / IP Logged
What kind of wiring diagram?  Stereo, alarm, remote start, cruise control, or all of the above???
Al Capone's business card said he was a used furniture dealer.
do0dfromcali
Member - Posts: 11
Posted: February 19, 2004 at 8:15 AM / IP Logged
Remote Start
do0dfromcali
Member - Posts: 11
Posted: February 19, 2004 at 8:19 AM / IP Logged
Also does a 92 accord have postive or negative triggers on the door locks?
do0dfromcali
Member - Posts: 11
Posted: February 19, 2004 at 7:44 PM / IP Logged
ttt
boomer_106
Silver - Posts: 710
Posted: February 20, 2004 at 9:37 AM / IP Logged
Negative.
Honda
Accord
1990-1993
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
BLACK/ WHITE
IGNITION SWITCH HARNESS
Ignition  #1:
BLACK / YELLOW
Ignition #2:
YELLOW
IGNITION SWITCH HARNESS (HEATER)
Ignition  #3:
N/A
Accessory:
WHITE/ BLACK
Brake  Light:
GREEN / WHITE (+)
AT SWITCH,BRACKET ABOVE PEDAL BRACKET
Tach  Signal:
BLUE
AT DISTRIBUTOR OR DASH FUSE BLOCK
Parking Lights:
BLACK/ RED (+)
HEADLIGHT SWITCH OR AT FUSE BOX
Headlights:
BLUE/RED
(-) AT HEADLIGHT SWITCH
OEM Alarm  Disarm:
BLUE OR BLUE/WHITE
(-) AT DIS-ARM SWITCH
OEM Alarm  Arm:
N/A
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
Honda
Accord
1990-1993
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
WHITE
Starter  Kill:
BLACK/ WHITE
Ignition  +12 Volts:
BLACK / YELLOW
Dome  Lights/Superv:
BLACK/ WHITE (-)
BROWN CONNECTOR ABOVE FUSE PANEL
OEM Horn:
BLUE/RED OR GRAY
(-) STEERING COLUMN HARNESS
Power  Lock:
BLACK/ WHITE
DRIVER KICK PANEL, 2 PIN PLUG TAPPED
Power  Unlock:
BLACK/ RED
TO HARNNESS ABOVE FUSE BOX *
Trunk  Release:
N/A
Alarm  Input Wire:
BLACK/ WHITE (-)
Notes:
* See Note #201 - Negative Pulse Door Lock Diagram.
do0dfromcali
Member - Posts: 11
Posted: February 20, 2004 at 12:43 PM / IP Logged
Sweet thanks
theromeo4u
Posted: February 23, 2004 at 4:22 PM / IP Logged
i have a 1992 accord Ex with a Honda factory alarm, but the car came with no transmitter nor does the alarm seem to go off.. the alarm serial # AVZ1102759  and another # AZ69Z4A088.  Can some tell me how to activate this alarm, how does it work and do you have a remote that i can use for it.. or any information you have about it.
Romeo4U
do0dfromcali
Member - Posts: 11
Posted: March 04, 2004 at 2:26 PM / IP Logged
Do you know the color wire for the o2 sensor? Hooking up a A?F guage
