car alarm
ddawg169
Posted: August 11, 2002 at 2:36 PM / IP Logged
i need a diagram for a 93 mazda mx-3 and a 2000 mazda 626. for installing a  car alarm. the mx-3 is the gs V6 model. thanks
David Covington
Moderator - Posts: 12,488
Posted: August 11, 2002 at 2:53 PM / IP Logged
Mazda MX-3:
|              12V|black               |+  |ignition harness            |
|          STARTER|BLACK/ blue          |+  |ignition harness            |
|         IGNITION|blue                |+  |ignition harness            |
|        ACCESSORY|BLACK/ red           |+  |ignition harness            |
|       POWER LOCK|actuator            |   |drivers door                |
|     POWER UNLOCK|actuator            |   |drivers door                |
| PARKING LIGHTS +|RED / black           |   |dimmer control switch       |
| PARKING LIGHTS -|green               |   |steering column             |
|       HEADLIGHTS|blue / YELLOW         |-  |steering column             |
|     DOOR TRIGGER|RED / white           |-  |3 pin plug above fuse       |
|  TRUNK/HATCH PIN|red                 |-  |at switch or light          |
|       TACHOMETER|yellow-blue         |   |at distributor              |
|       BRAKE WIRE|green               |+  |brake switch                |
|     HORN TRIGGER|grn/red or grn/blk  |-  |steering column             |
|           WIPERS|blue/white          |+  |steering column             |
|  LF WINDOW UP/DN|RED / blk RED / grn     |A  |in drivers door             |
|  RF WINDOW UP/DN|RED / wht blk/blu     |A  |in drivers door or dkp      |
Mazda 626:
|          STARTER|green               |+  |ignition harness            |
|         IGNITION|BLACK/ white         |+  |ignition harness            |
|  SECOND IGNITION|BLACK/ red           |+  |ignition harness            |
|        ACCESSORY|blue                |+  |ignition harness            |
|       POWER LOCK|BROWN / yellow        |-  |*2                          |
|     POWER UNLOCK|white & brn/wht *3  |-  |*2                          |
|       LOCK MOTOR|green               |   |drivers kick panel          |
|     UNLOCK MOTOR|pink                |   |drivers kick panel          |
|    DISARM DEFEAT|red                 |   |passengers kick panel       |
| PARKING LIGHTS +|RED / white           |   |green plug at fuse box      |
| PARKING LIGHTS -|lt GREEN/ red        |   |headlight switch            |
|       HEADLIGHTS|yellow              |-  |headlight switch            |
|     DOOR TRIGGER|RED / white           |-  |green plug at fuse box      |
| DOME SUPERVISION|use door trigger    |   |                            |
|  TRUNK/HATCH PIN|WHITE/ black         |-  |at light in trunk *5        |
|         HOOD PIN|                    |   |                            |
|TRNK/HTCH RELEASE|orange              |-  |*2                          |
|  FCTRY ALARM ARM|                    |   |                            |
|FCTRY ALRM DISARM|                    |   |                            |
| DISARM NO UNLOCK|*4                  |   |                            |
|       TACHOMETER|*1                  |   |ignition coil               |
|      SPEED SENSE|gray/blue           |   |instrument cluster or ECM *6|
|       BRAKE WIRE|purple              |+  |brake pedal switch          |
|     HORN TRIGGER|grn/red or grn/org  |-  |steering column             |
|           WIPERS|blu/wht(L),blu/red(H|+  |steering column             |
|  LF WINDOW UP/DN|red - RED / blu       |A  |drivers window switch       |
|  RF WINDOW UP/DN|grn/wht - RED / blk   |A  |drivers switch or kick panel|
|  LR WINDOW UP/DN|blu/wht - blu/blk   |A  |drivers switch or kick panel|
|  RR WINDOW UP/DN|grn/yel - wht/red   |A  |drivers switch or kick panel|
Notes:
NOTE:  This vehicle has an immobilizer system that needs to be bypassed when adding remote start. .  *1 Use red or green for the 4 cylinder and white for the 6 cylinder.  *2 Found at a tan module near the hood release.  *3 The white wire will unlock the drivers door only, and the BROWN / white will unlock the other doors.  use both wires and diode isolate each.  *4  To disarm with out unlocking, send a positive trigger to the blue / YELLOW key sense wire.  The key sense wire is located at the steering column.  *5 Can also find in drivers kick panel in the harness from the rear if the vehicle has a factory alarm.  *6 The ECM is under the center console. The VSS wire is in pin 58.
Monday, December 1, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
