rem start on a 02' celica
proinstall
Copper - Posts: 77
Posted: February 26, 2004 at 6:29 PM / IP Logged
I heard about something with the ignition wire needing a relay of some sort? Anywho I may be installing one tomarrow and I was wondering if anyone knew about one of these cars?
JMaxx93
Copper - Posts: 73
Posted: February 26, 2004 at 7:08 PM / IP Logged
JWorm
Platinum - Posts: 2,208
Posted: February 26, 2004 at 7:50 PM / IP Logged
That PDF applies if you are installing a remote start with external relays. If you are using one with internal relays, it gets wired differently. What are you using for a system?
daniel2002p
Silver - Posts: 524
Posted: February 26, 2004 at 7:51 PM / IP Logged
have to hook up a relay for each ignition.
2005 Toyota Corolla S
    1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
proinstall
Copper - Posts: 77
Posted: February 27, 2004 at 8:02 PM / IP Logged
its a compustar 2WSS-AS system
The pic is fine, thats all I need.. the compsutar has a - output for ignition that I can use..
