Sound damping question?
BubbasHouse
Member - Posts: 6
Posted: March 05, 2004 at 12:37 AM / IP Logged
Damping material is forgiving.  If the area you are attaching to is smooth you should have no problems and your ride could quiot down quite a bit depending on how much you use.  The problem with fiberglass is when the surface is not smooth.               Taunnue covers are horible to try to deaden.  Bonding area is less than half the total surface area.             Good luck
BubbasHouse
Member - Posts: 6
Posted: March 05, 2004 at 12:38 AM / IP Logged
my spelling can be horrific at time too.
Sunday, February 8, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
