Solara 04 wiring diagram
dlblue
Posted: March 04, 2004 at 8:29 PM / IP Logged
Anyone have wiring diagran for Toyota Solara 04. I'm waiting for the Viper791XV to install on my car, Please help if have the info.
Thank!
mobile1
Silver - Posts: 479
Posted: March 04, 2004 at 8:38 PM / IP Logged
12volts
wht/red (30A), wht (7.5A)
ignition harness
StarterBLACK/ white + ignition harness
Second StarterBLACK / YELLOW + ignition harness
IgnitionRED / black + ignition harness
Second IgnitionBLACK / YELLOW + ignition harness
Third IgnitionN/A
Accessoryblue/red + ignition harness
Second AccessoryN/A
Keysenseblue - ignition harness
Power Locklt. green - driver kick, 20 pin plug
Power Unlockblue (double pulse) - driver kick, 20 pin plug
Lock Motorblue / YELLOW 5widriver kick, gray 11 pin plug
Unlock Motorblue/black 5widriver kick, gray 11 pin plug
Parking Lights+green + driver kick, harness to rear
Parking Lights-red - headlight switch
Hazardslt. GREEN/ black - flasher relay in driver kick
Turn Signal(L)GREEN / WHITE or GREEN/ black + flasher relay in driver kick
Turn Signal(R)GREEN/ YELLOW + flasher relay in driver kick
Reverse LightRED / black + driver kick, 17 pin plug
Door TriggerRED / green (x2) - see notes
Dome SupervisionGREEN/ red - R side of fuse box, 12 pin plug
Trunk/Hatch PinGREEN/ red - driver kick, 17 pin plug
Hood Pinblack - BECU, 10 pin plug, pin 10
Trunk/Hatch ReleaseWHITE/ blue 5widriver kick, 17 pin plug
Brake WireGREEN / WHITE + brake pedal switch
TachometerBLACK/ orange ac ECM, connector E4, pin 5
Wait to startN/A
The driver door trigger is RED / green in the driver kick, in a 17 pin plug. The passenger door is RED / green in the passenger kick, in a 12 pin plug. Use both wires and diode isolate each.Using the status output to trigger this wire during remote start will disarm the factory alarm without unlocking the doors.
rudbwoy69camaro
Silver - Posts: 350
Posted: March 04, 2004 at 8:55 PM / IP Logged
Nice mobile1, care to share your directechs password(hehe)?
dlblue
Posted: March 04, 2004 at 9:11 PM / IP Logged
Thank for the wiring digran rudbwoy69camaro.
rudbwoy69camaro
Silver - Posts: 350
Posted: March 04, 2004 at 9:25 PM / IP Logged
Not me, Thank mobile1
dlblue
Posted: March 04, 2004 at 10:37 PM / IP Logged
Sorry about that rudbwoy69camaro.
One again thank for the info Mobile1 and everyone check my post.
