relay help!
heschlie
Member - Posts: 24
Posted: March 08, 2004 at 12:03 AM / IP Logged
ok im still new to this relay business and i wanted to know, for the radio on until door open would you use the acc for the fused +12v input or any costant +12v with an inline fuse.  like i said imnew to this and need help. thank you.
JakeJ
Member - Posts: 38
Posted: March 08, 2004 at 1:15 AM / IP Logged
   You need to use a constant. If you dont the radio will still go off with the acc. I asume you know of the diagram of how to wire the relays on this site. If not it is at the left of the home page under "Basics" - "Relays" - "Special Applications"   Good Luck!!
Wyoming 12volt Enthusiast
heschlie
Member - Posts: 24
Posted: March 08, 2004 at 2:14 AM / IP Logged
k thanks yea i know the diagram i was just curious, and just to check i do need an inline fuse, rated at whatever is on the end of the relay ie stereo, lights, and whatnot.
