triggering wipers on highlander
markcars
Silver - Posts: 662
Posted: March 08, 2004 at 10:47 PM / IP Logged
I have extra outputs from my RS/Alarm unit, and am not using them now. I don't have a trunk release, so I have 2 extra buttons/triggers I can use. I want to use one for making my wiper clean the front window and another trigger for the rear-window, if and when I need it, by pressing a button on my remote. Anyone knows what wires I must connect? HIghlander 03. Thanks.
mxxmikexx
Silver - Posts: 796
Posted: March 09, 2004 at 11:20 AM / IP Logged
my info says the front wipers should be a blue/black wire located at the ignition switch harness. so test that wire and see if thats it. i dont have any info for the rear wiper tho.
Mike Battaglia
Specialized Car Audio
Bensenville IL 60106
markcars
Silver - Posts: 662
Posted: March 09, 2004 at 11:48 AM / IP Logged
Thanks! If the wire for the front wipers are located at the ignition switch harness, then the rear one should be there too as both switches are on the same lever. I will test them.
Or is there anything better I can use the two extra triggers for? I have no ideas yet.
Thanks again.
Mark
mxxmikexx
Silver - Posts: 796
Posted: March 09, 2004 at 5:28 PM / IP Logged
either to control a window module,defroster,i sometimes hook it up to headlights so you can see as your walking to your vehicle at night...comes in handy sometimes.or maybe a sunroof module
Mike Battaglia
