clutch bypass ’94 Nissan Altima
profuse007
Gold - Posts: 2,015
Posted: March 18, 2004 at 9:44 PM / IP Logged
-i have been doin couple of MT cars and it works great but this fourth MT car that i just did couple of days ago is really crazy.
-this one is 94 nissan altima. the closest car to it that i did was a 95 nissan 240sx, i thought it would be the same, but its not.
-remote start works when the clutch is depress.... so thats out of the way, but now the clutch, it is weird as F**K.
-its a two wires clutch switch (like all the other ones) but normally closed, or pushed (the siwtch is locate infront of the clutch, not behind). all the other ones that i did were normally open and locate behind the clutch pedal.
-so then i tested both wires like usual they both get ground normal and depressed..... so then i couldnt do anything.
-BTW, took two days and couldnt find out how to bypass the clutch.
-someone out there, help me!!!!!
Houston,TX
bmf1000d
Silver - Posts: 345
Posted: March 18, 2004 at 10:00 PM / IP Logged
So if what your saying is correct then all you have to do is revers your wiring or am i not understading it?
"Big" Mike
Double Take
Fremont, Ne
remember to check all your wires with a dmm not a test light!!
i take no responsibilty whatsoever for the vailidty of the info nor consequences thereof
profuse007
Gold - Posts: 2,015
Posted: March 18, 2004 at 10:14 PM / IP Logged
am saying the wires doesnt change b4 or after depressin the clutch pedal.
Houston,TX
bmf1000d
Silver - Posts: 345
Posted: March 18, 2004 at 10:19 PM / IP Logged
I dont do many manuals so here is what i got here at the house
http://www.designtech-intl.com/Content/techsupport/documents/section04/note141.pdf
"Big" Mike
Double Take
Fremont, Ne
