98 cadilac catera alarm/remote start
Sound Pressure
Silver - Posts: 711
Posted: March 18, 2004 at 11:45 PM / IP Logged
Hello,
Wondering about the door locks on a 98 cadilac catera? What type of system are they? Are any relays needed for this or can I just tap into the factory unlock/lock wires with the alarm?
Thanks,
Sound Pressure
draasch
Gold - Posts: 2,172
Posted: March 19, 2004 at 5:49 AM / IP Logged
depends on the unit you are using and what the outputs are for the door locks....
Make:   Cadillac
Model: Catera
Year:    1998
This Database Was Last Updated On:    6/9/2003
Index #: 9959
Alarm
Constant 12 volts RED IGNITION SWITCH HARNESS
Ignition 12 volts BROWN IGNITION SWITCH HARNESS
Starter BLACK/ RED IGNITION SWITCH HARNESS
Dome Light GRAY (-) DRIVERS KICK PANEL *
Trunk Pin Switch BROWN / BLUE (-) AT LIGHT IN TRUNK
Parking Lamp GRAY/GREEN (+) AT RELAY BOX BEHIND DRIVER DASH
Power Lock BLACK/ BROWN EITHER KICK #201
Power Unlock BLACK/ VIOLET PANEL
#201- See Negative Pulse Door Lock Diagram. * Dome Light Also Found As BROWN / BLUE (-) In Driver Kick Panel (Rear Body Harness).
if you have neg outputs, then yes you should be able to hook right up....
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Platinum - Posts: 12,488
Posted: March 19, 2004 at 6:40 AM / IP Logged
POWER LOCK BLACK/ brown    (-)  24 pin plug, pin A8 @ BCM in the passenger kick panel
POWER UNLOCK BLACK/ purple  (-) 24 pin plug, pin A6 @ BCM  in the passenger kick panel
Sound Pressure
Silver - Posts: 711
Posted: March 19, 2004 at 11:23 PM / IP Logged
Thanks guys I appreciate it as always.
Sound Pressure
Posted: March 19, 2004 at 11:26 PM / IP Logged
No Problemo
Sound Pressure
Silver - Posts: 711
Posted: March 21, 2004 at 12:20 AM / IP Logged
Almost forgot about adding a remote start. Is there anything that has to be bypassed? I did not see anything on the wiring info.
Thanks,
Sound Pressure
Posted: March 21, 2004 at 1:52 AM / IP Logged
The Caddy has a Immobilizer system. There is no module that is keyless for this vehicle. You will need to use the TBKII or TBKIII key required bypass module for remote start bypass.
Sound Pressure
Silver - Posts: 711
Posted: March 21, 2004 at 2:07 AM / IP Logged
Thanks for your help jeff!
Sound Pressure
Sunday, April 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
