roof mount EQ rack
dirtdr
Member - Posts: 22
Posted: August 19, 2002 at 7:56 PM / IP Logged
I am putting together a roof rack EQ mount for a pair of Audio Control EQT's and my Crossover. It is going over the back seat of my Jeep Cherokee. I have the glassing all figured out and the eq's and x-over are going to be flush-mounted into the rack. the only prob i have is finishing. I want to wrap it with vynel -- where do i get the material from,?? and what is the best way to stick it on?? I also want to finish my kicks the same way, as well as custom sub boxes i am building.
check it out:
http://members.sounddomain.com/dirtdr74
Static Revenger
Member - Posts: 23
Posted: August 19, 2002 at 8:22 PM / IP Logged
You should be able to find some vinyl at a fabric store or any of your local upolstery shops.As for the adhesive I would use 3M's Super 77 spray adhesive which you should find at Wal-Mart if you have one near you,if not most but not all auto parts stores may also have it. roof mount EQ rack - Last Post -- posted image.
crroush
Copper - Posts: 151
Posted: August 19, 2002 at 9:12 PM / IP Logged
use the super 77, is one way, i would recommend stretching it and using staples or some form of fastening device, similar to how you would upolster a chair or something...just so that it looks good, the problem with the glue is that it only sticks to itself, so you have to apply it on both surfaces and depending on the fabric you use you may get some funny looking air pockets and things.
just before you start applying it, test the fabric, but I would secure it with more than just adhesive, also if you do staple, use a thin cardboard strip (also sold precut at most fabric stores) to staple to, just so it doesn't rip around the staple and gives a stronger hold.
Craig
dirtdr
Member - Posts: 22
Posted: August 19, 2002 at 10:07 PM / IP Logged
thanks. I appreciate the help.
GlassWolf
Copper - Posts: 365
Posted: August 20, 2002 at 10:52 AM / IP Logged
the real bitch of rood mounting is all the RCA lines you need to run up the pillars and back down.. very bulky
also very long, which will decrease signal somewhat
-GlassWolf
Pioneer Stage-4, Orion, DynAudio, Fi
DeathsJester12V
Silver - Posts: 352
Posted: August 20, 2002 at 7:52 PM / IP Logged
Another option for gluing the vinyl down, is this stuff by Dap....it slips my mind what it is exactly called, but I know it is sold at home Depot and comes in 1 gallon containers...the problem is, is it's made for a spray gun that hooks up to an aircompressor....But it works Hellagood!!
As far as the Vinyl goes...Check out Select Products: http://www.selectproducts.com  ( they also sell glue to use )
Also if you have any sharp curves or tight bends that you are wrapping....use a heat gun on low heat...and I mean low heat, and keep the gun atleast a foot if not more away from the vinyl....don't wanna scorch it do ya..you can also use a little hook tool to press the vinyl in tight spots...just please make sure you are using the back of the hook and not the actual hook....otherwise...whoops sux to be you, you just tore your vinyl.
And like Glasswolf said...you're gonna have a big bundle of wires to run up and down the a-pillars...you will lose some signal so be warned...what you might wanna do is find a way to run the rca's up the a-pillars going to the eq's and x-over...and than run them to the back of the vehicle than down, instead of going back down the a-pillars....but it depends on how much work you wanna do..it also depends on where you got your amps at...
hope this helps
Đễẳ†ђş 12\/ Ĵęśŧē®™
dirtdr
Member - Posts: 22
Posted: August 20, 2002 at 9:31 PM / IP Logged
thank you. i was just gonna ask about curves with vinyl.
As for the rcs's, I already have the length requires for the roof mount (the excess is just wrapped up for the time being) and I will have a total of 4 rca sets ( 1 in 3 out) and power grnd, rem wires. I have already planned on running each their own pillar... input from front . sub down middle of one side, mids, tweets down other, and power, ground and rem right from the back hatch area (since that is where my dist blocks are gonna be). The only delema i am having about that is cutting a hole in the headliner for the wires (since the eq pod will not go right to the edge of roof), but i have already hacked up enough stuff in this jeep that it is hardly worth saving the headliner. The one idea i had was making a tunnel out of glass from the pod to the roof light and run the wires there, since there is a hole already inder the light..... but no.
Thanks again for all the help
dirtdr
Member - Posts: 22
Posted: August 21, 2002 at 8:16 PM / IP Logged
Damn!! good thing I bough lots of viynl. I'm gonna need it. It came out with a few wrinkles, so I might re-do the covering job..... later. I've taken 4 days off work to build this thing and I have to get makin some more money pretty quick
dirtdr
Member - Posts: 22
Posted: August 21, 2002 at 10:50 PM / IP Logged
ok the eq rack is in... not the prettiest. I did a real butcher job on the viynl. I got to that point in the project where you can see and end and can't frikin wait to get it done.. but it is in..next holiday i will fix it. It still looks better than everything bolted to the back seat like it was before
Wednesday, February 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
