2000 civic alarm/ RS
quixs1lver
Copper - Posts: 67
Posted: March 28, 2004 at 5:12 PM / IP Logged
installing python 3000 esp and a valet 551t
i have a factory keyless entry in the car. but i dont know where all the wires actually are/ keyless entry module are located.
so where is the wire for the door pin
trunk pin
e-brake wire in the dash loom.
draasch
Gold - Posts: 2,172
Posted: March 28, 2004 at 5:30 PM / IP Logged
Make:   Honda
Model: Civic
Year:    1999-00
Alarm
Constant 12 volts WHITE IGNITION SWITCH HARNESS
Ignition 12 volts BLACK / YELLOW IGNITION SWITCH HARNESS
Starter BLACK/ WHITE IGNITION SWITCH HARNESS
Dome Light L GREEN/ RED (-) 24 PIN BLUE CONN. TOP FUSE BOX *
Trunk Pin Switch BLUE/BLACK (-) 16 PIN BLUE CONN. BELOW FUSE BOX
Parking Lamp RED / GREEN (+) 7 PIN GREEN CONN. AT FUSE BLOCK
Power Lock GREEN / WHITE 18 PIN GRAY CONN. IN DRIVER KICK
Power Unlock GREEN/ ORANGE PANEL AT DOOR LOCK MODULE ** #201
* Has Also Been Found As L GREEN/ BLACK At Door Lock Module In Drivers Kick. ** Location Listed Is With OEM Keyless. Without OEM Keyless Wires Can Be Found In A 14 Pin GRAY Conn In GX Models. In All Other Models It Can Be found In A 20 Pin GRAY Conn. #201 - See Negative Pulse Door Lock Diagram.
View Diagrams
Accessories
Window Up D\ RED / YEL P\ BLU/YEL D\ GRN/YEL P\ YELLOW @ MAIN
Window Down F/ RED / BLU F/ BLU/ORG R/ GREEN R/ YEL/GRN SWITCH #211
Ign Key Warn BLUE/WHITE (-) 7 PIN BROWN CONN ABOVE FUSE PANEL
Trunk Release N/A
OEM Horn GRAY (-) 3 PIN GRAY CONN. *
Headlights RED / WHITE (+) US MODEL RED (+) CANADA AT HEADLIGHT SWITCH
OEM Alarm Arm ARMS THRU OEM REMOTE OR PASSIVELY
OEM Alarm Disarm DISARMS THRU REMOTE OR THRU OEM VALET
* GRAY Wire Changes Color To BLUE At Steering Column. At 3 Pin GRAY Conn. In Steering Column Harness #211 See Reversal Rest At Ground Window Circuit.
View Diagrams
Remote Start
Tach Signal BLUE 2 PIN WHT CONN UNDER HOOD DR REAR
Ignition #2 YELLOW IGNITION SWITCH HARNESS
Ignition #3 N/A
Accessory WHITE/ BLACK IGNITION SWITCH HARNESS
Neutral Safety NOT GROUNDING TYPE - OEM SWITCH OPENS STARTER CIRCUIT
Brake Light GREEN / WHITE (+) SWITCH ABOVE BRAKE PEDAL
Reverse Light GREEN/ BLACK (+) 20 PIN GRAY CONN IN DR KICK PANEL *
Rear Window Defrost N/A
* GX Model Have 14 Pin Gray Conn In Driver Kick Panel.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
quixs1lver
Copper - Posts: 67
Posted: March 28, 2004 at 9:09 PM / IP Logged
i want to have the remote start only operate with the hand brake on? where can i find the hand brake wire w/o having to take out center console?
draasch
Gold - Posts: 2,172
Posted: March 28, 2004 at 9:28 PM / IP Logged
do u have a standard tranny???
Good Luck
David
Ace Security
813-376-9778
Tampa
quixs1lver
Copper - Posts: 67
Posted: March 29, 2004 at 6:38 AM / IP Logged
yea i have a manual.
Sunday, July 6, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
